It is currently Thu Oct 22, 2026 2:55 pm
Vehicle: sj413
Post Posted: Tue Aug 11, 2015 4:59 pm
I have put an early vitara rear lock rite into a 413 rear different but never even seen the insides of a Jimmy diff . A mate has asked if a mid 90's vital rear lock rite would fit a Jimmy rear ? Anyone got any info on this .
Thanks
Chris
Post Posted: Wed Aug 12, 2015 4:28 am
oops. Nothing here to see....
-Ack
http://www.acksfaq.com
88, 88.5 SJ413
Post Posted: Wed Aug 12, 2015 6:24 am
Send an email to Dave Jones at bits4vits in the UK, he has a Vit LSD fitted in a Jimny axle. It was fitted by Rockwatt Engineering. From what I recall from a thread on BigJimny the centre size is the same or similar, Dave or Richard would know for sure.
Post Posted: Wed Aug 12, 2015 7:13 am
The easy way would be to look up lockrite and see what they specifi for each car, I'm pretty sure vitara's sierras and Jim's all run the same rear lockers
Post Posted: Wed Aug 12, 2015 12:03 pm
Jack is correct
Vits use the same locker pieces, except they retain the factory pins, where the sierra requires new pins, as it has grooves cut into the pins to allow lubrication, but these also act as weak points where cracks occur.
It will work, but depends on the pins in the rear of the jimny.
If you dont use new pins, it may eventually fail.
Vehicle: LJ50V 2 stroke
Post Posted: Wed Aug 12, 2015 2:43 pm
i had a Jimny auto locker in my sierra.
it'll fit
Users browsing this forum: Google [Bot] and 155 guests
