It is currently Fri Oct 23, 2026 11:52 am
Post Posted: Mon Aug 17, 2015 12:05 pm
I have lost misplaced my keys and have torn the joint apart!
Are any other barrels the same?
There are 4 wires going into the barrel is it as easy as 2 for accesories and 2 to start so I could just put in 2 switches?
Thanks
Post Posted: Mon Aug 17, 2015 3:10 pm
Also is wt and nt the same?
Post Posted: Mon Aug 17, 2015 3:28 pm
Wires should be:
-Permanent power TO switch
-Accessories power FROM switch
-Ignition power FROM switch
-Start signal FROM switch
If you jump a wire from permanent to ignition, then another from permanent to start it should fire into life.
Post Posted: Mon Aug 17, 2015 4:25 pm
I think I have sourced a barrel and door locks but if it falls through I will try work out some switches and push button start!
I have heard nt and wt are different.... Is this true?
Post Posted: Wed Aug 19, 2015 8:20 am
The key number is on passenger side door lock, just get one cut
Bye
Post Posted: Wed Aug 19, 2015 4:21 pm
What? Haha
Users browsing this forum: No registered users and 134 guests
