It is currently Thu Oct 22, 2026 9:38 am
Vehicle: 95 maruti trayback
Post Posted: Tue Sep 01, 2015 2:58 pm
Is anyone running an auto locker in the rear of there gv/vit? How does it handle on the road? I'd love to get one but onroad driving with one is my only concern. Cheers
Post Posted: Tue Sep 01, 2015 3:22 pm
Handles just fine, the only time you even notice them is at slow speeds going around corners.
Main thing is changing your driving style to suit (ride the clutch a bit more around slower corners etc). If you don't they'll buck and bang and carry on a bit.
Front ones are far more noticeable (obviously only when in 4WD/offroad). They add a significant return to centre steering effect and can make turning on higher traction surfaces an effort.
Change ratios at the same time IMO, if you are going to the effort of putting lockers in you may as well do the ratios while you are at it. Lockers will let you approach things at a much slower pace, so lowers gears go hand in hand with em as you won't have to ride your clutch so much.
Post Posted: Tue Sep 01, 2015 3:32 pm
Ok thanks heaps mate. I'm going to 4:8 gearing now as my front diff decided it would rather be in heaps of little pieces than one piece
Post Posted: Tue Sep 01, 2015 8:50 pm
Yeah i would agree with Ninja, well worth the slight hassle.
Post Posted: Tue Sep 01, 2015 11:54 pm
It may depend on where you are and how you are forced to drive - coasting through corners is not always an option - and if you have an appreciable number of "up slope" turns (not necessarily uphill) you're going to be hearing that bang and feeling that buck - if you're forced, as I am, because of the intersections & stop signs to turn with the power on so you can merge into the traffic stream, you're going to hate it.
Vehicle: sj80 w/myside2. 99GV 2.5V6
Post Posted: Wed Sep 02, 2015 9:09 pm
If you have an auto, the box will act as a shock absorber.
Definatley doable with a manual, but driving style has to be modified to suit.
I had one in the rear with a heavy duty clutch and managed fine until I sold the car.
my missus hated it though and avoided driving the car.
Was fantastic offroad
Going back to a normal diff (well LSD in this case) I do prefer the smoothness and will go to an elocker this time.
Vehicle: 99 Grand Vitara
Post Posted: Thu Sep 03, 2015 9:37 am
I drove my mates manual gv with a lockright in the rear, was the biggest pig to drive... I definitely prefer to drive around with my welded diff...
http://www.strictly4x4.com.au
Post Posted: Thu Sep 03, 2015 11:39 am
Welded diffs are a pain in the backside, increased tire wear, chunking, scuffing, larger turning circles, squealing over painted lines in parking lots - but they are predictable - no twitching, no banging ...
Post Posted: Fri Sep 04, 2015 12:19 pm
I would not use either welded or auto in a GV.
In my opinion the axles aren't strong enough to last with a welded diff, and autos are piggy.
Post Posted: Sat Sep 05, 2015 8:22 am
I can confirm this....... GV Axles are definitely not strong enough to handle a rear Auto or welded diff. but currently there are no other off the shelf options for axles.
Post Posted: Sun Sep 06, 2015 5:19 pm
Actually now you bring that up when I removed the locker from the rear the splines had twisted a little on one axle.
Users browsing this forum: Google [Bot], phlix and 127 guests
