It is currently Thu Oct 22, 2026 6:19 pm
Vehicle: 91 sj70 twin locked
Post Posted: Wed Sep 02, 2015 4:16 pm
Baleno 99 model conversion into Sierra
Hi all have done a few baleno conversions from manual balenos
Into sierras no problem
But this time I've used a baleno donor witch was a auto
And having real issue with wireing won't start has any used the auto
Baleno computer before is there something I'm missing
Any help would be great thanks
Post Posted: Wed Sep 02, 2015 5:00 pm
Some have imoberlisers
Post Posted: Wed Sep 02, 2015 7:32 pm
Did you check the wire to starter motor?
There is the inhibitor switch, which needs to be bypassed as no longer relevant.
Post Posted: Wed Sep 02, 2015 9:48 pm
Factory imobiliser will screw u
Post Posted: Wed Sep 02, 2015 10:25 pm
Not first one I've done is the 4th but this is first auto is there any diff in computer
Post Posted: Thu Sep 03, 2015 7:23 am
All the info i could find when i did my swaps advised against using factory immob and auto harness/ecu. There are a few variants of ecu and not easy to find ecu pinout for all of them. Not sure if the auto ecu will work properely without the auto.
I found most helpful info on redlinegti and uk baleno forums.
Post Posted: Thu Sep 03, 2015 8:54 pm
Ok have put the auto computer in mine to test the computer and it runs mine perfect
So must be in the harness in engine bay time to start digging the auto harness must be different in engine bay
As this is the 4th conversion I've done and the first time it's played up
So that's where I'm at time to find where the break is lol
Post Posted: Fri Sep 04, 2015 6:10 am
Trace wiring back from the starter trigger, it's not hard to find
Users browsing this forum: Google [Bot] and 74 guests
