Vehicle: Zook Vitara
Posted: Sat Oct 10, 2015 5:05 pm
Hi all. I have noticed the last couple days that my clutch is slipping a bit when in 4th gear. Only seams to be in 4th haven't noticed it in any other gear. What's the most likely cause of this? It's a 90 jlx vitara.
Last time i had this happening it was the gearbox seal leaking oil into the bell housing, which eventually wet the clutch. It was only noticeable at higher RPM in higher gears, then eventually got worse and worse.
Users browsing this forum: Google [Bot] and 153 guests
