It is currently Fri Apr 17, 2026 6:27 am
Vehicle: Suzuki Grand Vitara
Post Posted: Wed Oct 21, 2015 4:06 pm
Hey i need to change the oil in my gearbox. What do i need? Torx?
Please help!
I have 75-90 oil and 80-90 oil.
Vehicle: JB420, APK416, A6G415, A6N415
Post Posted: Wed Oct 21, 2015 11:37 pm
It's a 10mm square recess, looks a lot like a 3/8" square drive socket, but it is slightly larger, and if you use the 3/8 it can slip and destroy the plug.
Make sure you remove the fill plug first.
Post Posted: Thu Oct 22, 2015 3:47 pm
Hi guys. Is the transfer case and gearbox oil seperrated? Can I change all the oil from the transfer case plugs? On my car the there is a fill plug on the gearbox that has a large torx drive head. Not a square drive. The transfer case has the 10mm square drives.
Vehicle: zook
Post Posted: Thu Oct 22, 2015 7:34 pm
The transfer contains its own oil and is entirely separate from the gearbox although they look joined. The section directly under the main gear lever is dry. (assuming manual?)
If the main box has a torx plug you are winning already.
Post Posted: Thu Oct 22, 2015 7:57 pm
Yeah but the distance between the gearbox and tunnel is about 35mm and I can't get a torx socket on!
Users browsing this forum: No registered users and 7 guests
