Joined: Tue Jan 10, 2012 3:48 am Posts: 253 Location: melbourne
Posted: Mon Jan 11, 2016 2:18 pm
Hey guys , So the troubles started yesterday in the way home . It feels like the clutch is not disengaging. I have to match revs to speed to get into gear and can't shift into reverse with the engine running. Though I can stop while in first no problems .
Leads me to belive it's the clutch cable, but it all seems to look fine. It's hard to see what happens when the clutch pedal is depressed on my own though. I've tried adjusting it a little but there doesn't seem to be a reason itbwould slip through without there being something else wrong.
I've never done anything to do with clutches so scratching my head a bit.
Posted: Mon Jan 11, 2016 2:54 pm
Clutch is about 80,000 ks. I adusted the cable tighter and no luck just meant it would slip when in gear , but still couldn't get in to reverse or first like it should. That's about all my ideas done
Vehicle: Suzuki sierra
Posted: Mon Jan 11, 2016 5:46 pm
Going through the same thing though I think mine is clutch cable stretching. Going to Wizz the box out and throw a clutch at it anyway. Has anyone had issues with a bent clutch fork?
Users browsing this forum: No registered users and 217 guests
