It is currently Thu Oct 22, 2026 2:36 am
Vehicle: 2012 SUZUKI JIMNY M18A AUTO
Post Posted: Mon Jan 11, 2016 8:41 pm
Hiya all
I did search but found a lot of conflict so my question to you is my current stock ht tyres are 205/70/15,
Now if I go up to let's say a 215/70/15 would that alter my speedo or perhaps rub?
My jim is stock suspension wise and I would like to keep the profile the same just go a bit wider.
Tanku
Vehicle: Suzuki Jimny 2009
Post Posted: Mon Jan 11, 2016 8:50 pm
215/75/15 is the biggest size you should go without modifications. Your speedo will then be spot on. You should not have any rubbing although this is possible but only slight when suspension has bottomed out. Some report no rubbing at all. You will notice the change in diameter when going up hills and will need to change gear a little earlier. If there is a 215/70/15 available that would be even closer to the stock conditions.
Post Posted: Mon Jan 11, 2016 11:03 pm
215/75r15 bfg km2 rubbed on the front of the rear guards on my uncle's jimny.
Vehicle: Suzuki Jimny Sierra 2015
Post Posted: Sat Jan 16, 2016 6:08 pm
Just put 215/75R15 M/T's on mine the other week, speedo is as mike said spot on 60 is now 60 on my gps and gauge!
Bit of rub reversing into car port at full lock I have noticed but due to the angle of the driveway as is hasn't happened on the flat.
Also when loaded with camping gear bit of a scrub on the right rear at 100 km/ph with country roads. so will lift and get front and rear bars one day in the near future :)
Vehicle: 2015 jimny
Post Posted: Fri Jan 22, 2016 11:57 am
I've seen heaps of jimnys for sale recently with like 30" tyres (or bigger) which look like they haven't had the guard chop (as far as I could tell from pics at least) , is this because of the offset wheel they are running to get away with it ? also all the ones i see for sale with 30's and that haven't had any kind of gear reduction etc so they must be shit in low range?
Post Posted: Fri Jan 22, 2016 12:01 pm
They don't really scrub once you lift it and it's on level ground... it's as soon as you compress the springs that things get clunky.
Vehicle: WT sierra, GU CRD
Post Posted: Fri Jan 22, 2016 4:46 pm
My brother's scrubs from time to time at compression.
30s and no gears sucks on road and off unless you are driving bog holes. Fitted xfer out of an auto and it rocks.
I love ZD30. :)
Users browsing this forum: No registered users and 197 guests
