It is currently Thu Oct 22, 2026 9:36 am
Vehicle: Suzuki sierra
Post Posted: Tue Jan 12, 2016 7:56 pm
Gday lads wondering if anyone one here has done an auto conversion in their g16b sierra.
Post Posted: Tue Jan 12, 2016 8:38 pm
Yes, you can use either Vitara automatic depending on what gearing outcome you are looking for.
Post Posted: Tue Jan 12, 2016 10:07 pm
Cheers. I'd probably want a 4 speed I think.. what vits came with the 4speed?
Post Posted: Wed Jan 13, 2016 5:53 am
Any Vitara with. G16b
You'll need flex plate &bolts , converter, loom, TCC, shifter from the donor Vitara.
You'll need to shorten your jackshaft
You'll need to modify your transmission crossmember and use something like the trail tough fitting kit to get it in.
Post Posted: Wed Jan 13, 2016 9:15 am
Any idea how much the jackshaft needs to be shortened ?
Post Posted: Wed Jan 13, 2016 9:23 am
Its in the install instructions for the trail tough kit
Post Posted: Wed Jan 13, 2016 9:37 am
I don't recall the exact dimensions by it roughly halves the length of the tube.
Mine has been in a while and I have no problems with vibration or uni life.
I wonder if TT have fixed their instructions for machining the slip yoke yet?
Post Posted: Wed Jan 13, 2016 2:43 pm
These are there instructions I was supplied from TT with kit about 9 months ago. Still a fair way off from this stage but I also heard from someone the instructions for jack shaft mod were incorrect?
Post Posted: Wed Jan 13, 2016 2:50 pm
Jackshaft instructions are correct as far as I recall.
The machining guide for the yoke is completely incorrect. It only needs to be shortened 25mm from memory.
Users browsing this forum: Google [Bot] and 100 guests
