Joined: Tue Jan 05, 2016 5:54 pm Posts: 14 Location: Rockhampton
Vehicle: 2005 Suzuki Grand Vitara V6
Posted: Tue Feb 16, 2016 8:52 pm
Anyone know of a reputable A/C shop in Brisbane? My GV is 11 years old and 42,000km never had work done on the A/C, the light occasionally flashes on the A/C button, still works OK but I suspect the gas needs a top up? Still seems to be quite cold though. IF I was home in Rocky, no problem but don't know any shops in Brisbane.
If the reason for the question is the flashing a/c button - a regas will probably not solve that - the flashing a/c button indicates that the BCM has detected an a/c related problem, usually a stuck actuator or similar issue.
Find someone with a copy of the FSM, there should be a way to get the BCM to flash the failure code on the a/c light.
Posted: Wed Feb 17, 2016 6:32 am
Thanks for the heads up on that, yes the light flashes occasionally but I don't think the compressor is dropping in and out. I THINK I may have my workshop CD on my PC I have with me, need to check......... Would not surprise me if it needed gas after 11 years, but I do run the A/C up every 3 months when the car is not being used much.
Users browsing this forum: Google [Bot] and 141 guests
