It is currently Sat Oct 24, 2026 3:36 am
Post Posted: Sun Sep 20, 2009 1:01 am
hey im trying to think of ways to unbend my axle housing. I was thinking about heat and bending (very very slowly) or a chain block, cold bending it back. What have people done in the past?
Post Posted: Sun Sep 20, 2009 1:10 am
An I beam, 2 chains and a hydraulic jack will do it.
Post Posted: Sun Sep 20, 2009 1:15 am
cheers thats a top idea :D :D i might make a brace for it while its out and fully pulled apart... hmm do i care that much...lol
you will need to use something a bit better then a wooden ruler to measure it.
a welder would do the job. :wink:
Post Posted: Sun Sep 20, 2009 1:23 am
Nothing is cracked and im not planning on taking any steel out of it, so what the welder for? Yeah i know i was just trying to show you how bent it is... I checked the knuckles and there not twisted whish is something i was worried about...
Post Posted: Sun Sep 20, 2009 1:36 am
welding steel has the side affect of bending it, therefore a welder can be used
to straiten a diff. have you ever noticed how people who know what they are doing, put a diff in a jig before welding. :wink:
Post Posted: Sun Sep 20, 2009 2:20 am
Yeah i always pre-load a diff housing a few thou in a jig before welding bracing in. And then do small stich welds, not massive continual runs. They bend like a banana otherwise. :D
Using some heat whilst doing the I beam trick would be the best bet. won't be as stressfull on the steel as cold bending would be.
Post Posted: Sun Sep 20, 2009 2:55 am
how big was the air time??
was it bigger than these...
http://www.youtube.com/user/panteracfh# ... _hwkc5V3OE
http://www.youtube.com/user/panteracfh# ... 2uTIawplk4
Post Posted: Sun Sep 20, 2009 3:53 am
Thats air time? Hmm must be a nissan thing :D
Post Posted: Sun Sep 20, 2009 12:50 pm
yeah an oxy does the same thing
Post Posted: Sun Sep 20, 2009 12:58 pm
Thats after the milk crates have been used to "set the job up" of course! :wink:
Post Posted: Sun Sep 20, 2009 1:05 pm
ok im glad someone told me to pre load it :D
Im off to go bendind
Post Posted: Sun Sep 20, 2009 1:08 pm
WAY WAY BIGGER bottom of my wheels were at rockhoppers door handles.... :D
Post Posted: Sun Sep 20, 2009 1:20 pm
and to give you an idea, my Sierra has 2" spring and bodylift and 31's, so yeah, it got some height :lol:
Post Posted: Sun Sep 20, 2009 4:58 pm
i nerd the landing! Was that loud i though it my transfercase destroying itself!
navara on 33s. hopfully rear air locker soon
Post Posted: Sun Sep 20, 2009 5:27 pm
All i can remember is some smooth sailing for a couple of seconds...lol
Post Posted: Mon Sep 21, 2009 1:02 am
my 2mm out is gay enough to not let the CV slide in without the knuckle off... im going to find a wt front diff soonish...
Post Posted: Mon Sep 21, 2009 1:28 am
hope you have it ready for yawal. your coming to yawal arnt you?
Post Posted: Mon Sep 21, 2009 1:30 am
ahh when?
Post Posted: Mon Sep 21, 2009 1:31 am
11th oct from memory. but im keen to do a trip before then.
Post Posted: Mon Sep 21, 2009 1:34 am
das only three weeks away, prob not mate i just stuck my mini tyres onto my swb and the lwb has motor all over the bench... ill be keen in about a month
Post Posted: Mon Sep 21, 2009 2:07 am
The bent housing should be good for cornering 8)
Just need to match the rear so the contact pattern is the same 8)
You need more air Armsup With your hands up in the air Armsup
ps. dont be a bogan. :lol:
Post Posted: Mon Sep 21, 2009 10:53 am
lol. Just put it back in. It'll probably bend itself straight at Yalwal
Post Posted: Mon Sep 21, 2009 9:30 pm
BHAHAHA you all shut up... im trying to sell the freaken thing and the only way to do that is to save money to fix the lwb... bent housings cost monies :D:D
Users browsing this forum: No registered users and 148 guests
