It is currently Sat Oct 24, 2026 2:03 pm
Vehicle: LWB Sierra & XL7
Post Posted: Tue Mar 08, 2016 10:42 pm
It's something I should've done with my old Vitara, and is something I should do on my GV. These two mods seem to go hand in hand but I don't plan on running larger tyres just yet.
Anyways, The question is, Do you have to do the Hagen widening / spring relocation mod to do the CV Stubby conversion?
I would imagine no, but thought I'd double check before I start pulling things apart.
Also instead of drilling new holes in the chassis, these would achieve the same result, correct?
http://www.bits4vits.co.uk/store/grand- ... d_964.html
thanks.
'92 Vitara & Camper trailer
Post Posted: Wed Mar 09, 2016 7:46 am
No, you don't need to do the mod to run a stubby shaft, it's for the hilux cv's.
Post Posted: Wed Mar 09, 2016 10:05 am
Thanks Steve, much appreciated.
Just one other thing, In all the stubby conversion threads I find they seem to use an old rear axle, cut it down and weld it. Surely the same can be achieved with an old passenger side CV, after all it is just the flange that's needed. Would there be any issues by doing it this way?
Post Posted: Wed Mar 09, 2016 10:08 am
I think the ones I've seen were based on a passenger side axle
Post Posted: Wed Mar 09, 2016 4:29 pm
Stubby shaft doesnt work on a GV very well as the drivers diff bracket is in the way. Gotta do alot of work to make it fit.
Post Posted: Thu Mar 10, 2016 5:46 am
Mine is a front inner axle and a cv bucket cut and welded (by a driveshaft company)
Post Posted: Thu Mar 10, 2016 5:51 am
Vehicle: SWB Vit
Post Posted: Thu Mar 10, 2016 3:55 pm
^^ Any chance you have an overall measurement of the finished item?
Would be nice to know how far the cv bucket was cut down.
Post Posted: Thu Mar 10, 2016 4:29 pm
As far as they could cut, leaving enough room for the metal dust sleeve was what I asked for.
It turned out slightly tight, so I spaced the diff over with washers about 1mm. That was perfect.
Later I added caster/or correction bushes, which gave it another 1mm of clearance.
Vehicle: SWB Vit
Post Posted: Thu Mar 10, 2016 4:34 pm
Thanks for that, I did wonder if there was enough room left for the dust sleeve.
Post Posted: Thu Mar 10, 2016 4:37 pm
http://imgur.com/a/5EtVc
Vehicle: SWB Vit
Post Posted: Thu Mar 10, 2016 4:58 pm
Awesome!!
Post Posted: Fri Mar 11, 2016 9:05 am
Thank you very much kind sir :)
Vehicle: SJ80, SE416
Post Posted: Fri Mar 11, 2016 8:15 pm
X2. Thank you Christover for going to the trouble of documenting the project.
Vehicle: 1990 swb auto vitara soft top
Post Posted: Mon Mar 28, 2016 7:32 pm
Shame no one does these as a kit, I'm already too busy with an aw4/efi conversion on the wife's car but this would be a handy conversion
Post Posted: Tue Mar 29, 2016 1:24 pm
Unlike bash plates etc, I'm sure this mod is a do at your own risk sort of thing, so it would be unlikely that a company would look at making up kits for something not many people would do in the first place.
My welding is average at best so I'm just going to precut them and dropped the piece's off to a driveshaft or engineering company they can TIG weld it.
Users browsing this forum: No registered users and 221 guests
