It is currently Thu Oct 22, 2026 11:42 pm
Vehicle: MG410
Post Posted: Wed Feb 13, 2013 1:53 pm
http://suzistore.com.au/onlinestore/fou ... etail.html
what bush is this and is it required?
I ordered a kit from LROR and it does not come with one
when i removed by shifter all i found was ths top bush.
Post Posted: Wed Feb 13, 2013 4:23 pm
goes under the shifter ball. Keeps the shifter nice n tight rather than all sloppy n loose..... Virginity bush if you like ;)
Theres a bloke on here who makes em out of poly for cheap. cant remember his ID though.
Im talking about T-case here btw... what are you talking about.
MY BUILD THREAD HERE!!!!!
Post Posted: Wed Feb 13, 2013 4:29 pm
pompoms pompoms
Post Posted: Wed Feb 13, 2013 4:31 pm
You talking G/box bush or T/case bush?
Either way I do them both. Bloody WAYYYYYYYYYYY cheaper than anyone I know.
Vehicle: 86 SJ413 dings / rust / 30's
Post Posted: Wed Feb 13, 2013 4:44 pm
Do you have a sloppy stick.. keeps popping out of where you put it? sounds like a loose bottom bush for your gear lever...
Vehicle: MG410
Post Posted: Wed Feb 13, 2013 7:15 pm
Im talking about the gearbox bush
just done a strip and rebuild with all new bearings and seals
When i removed the shifter the bush was badly disintegrated
Does the gearbox shifter run two bushes or just the one? From the suzistore website, it shows a listing for a bottom and a top gearshifter bush
What about the transfer shifter? suzi store only lists one bush for this
This is the kit i ordered from LROR
What i need to know is if I have enough bushes?
thanks
Post Posted: Wed Feb 13, 2013 7:19 pm
Are we still talking about cars here?
Post Posted: Wed Feb 13, 2013 9:25 pm
The very first of the 1 litre sierra had a bush under and on top of the ball for the gearbox gear lever , from 82 onwards they only had the bush on top of the ball on the gear lever.
Vehicle: 1984 NT High Top
Post Posted: Wed Feb 13, 2013 9:43 pm
There is definitely two bushes.
I bought two for $22 each from the local suzuki dealer.
Absolute rip.. Couldn't fit the bottom one so just did the top one.
Vehicle: MG410
Post Posted: Wed Feb 13, 2013 11:40 pm
thanks gents
exctly the info i was after
Vehicle: 1994 Sierra soft top
Post Posted: Mon Mar 14, 2016 6:31 pm
Hey Bruce do you still make the sierra gear shif bush ? Mine has a sloppy hole ha ha
Post Posted: Mon Mar 14, 2016 9:06 pm
He sure does. Might pay to flick him a pm
Post Posted: Tue Mar 15, 2016 3:59 am
Shark I was told by someone on here that some places sell you two bushes so you can do both cases whilst flooring up.
bye
Vehicle: SJ70 Tintop, SJ51T, 97 Coily
Post Posted: Thu Mar 17, 2016 6:21 am
Every manual, SJ70, SJ80, Drover, I look at shows only a top bush in the transmission, are the early models different?
Users browsing this forum: No registered users and 153 guests
