It is currently Sat Oct 24, 2026 11:30 am
Vehicle: 1991 Geo Tracker
Post Posted: Wed Mar 16, 2016 2:39 am
Has anyone had any experience with the 4.5 Inch 1st Generation Suzuki Suspension Lift from Zuki Nation or Altered Ego Motorsports in Kelowna, BC, Canada? Besides the regular 1.6 Liter models, they also claim that they have one for the 1.8 Liter Sidekick Sport, which should be compatible with the 1st Generation 2.0 Liter Vitaras. You'll have to scroll down at the following link or URL:
http://www.alteredegomotorsports.com/tr ... nsion.html
Post Posted: Wed Mar 16, 2016 5:40 am
Altered Ego 4.5" lift install:
http://www.zukikrawlers.com/showthread.php?t=42276
Post Posted: Wed Mar 16, 2016 6:30 am
Yuck.
Post Posted: Wed Mar 16, 2016 6:33 am
Same Altered Ego 4.5" lift install project, but different email threads with some different pictures & comments:
http://bbs.zuwharrie.com/content?topic=120903.0
http://www.pirate4x4.com/forum/suzuki/9 ... front.html
Post Posted: Wed Mar 16, 2016 7:30 am
wow
that looks like a terrible idea
9" lift total when running 31" tyres 8O
Post Posted: Wed Mar 16, 2016 7:45 am
jdk81 wrote:
wow -- that looks like a terrible idea -- 9" lift total when running 31" tyres 8O
The 9" lift total is optional. The relevant issue is the reliability of the lift kit.
Post Posted: Wed Mar 16, 2016 8:22 am
The strut spacer at the knuckle is the thing i cant get my head around. It stops the steering arm pointing upwards a bit but thats it. Its the pivot points that determin the path isnt it. What it does do its put the strut bolts in a single sheer
Post Posted: Wed Mar 16, 2016 8:26 am
Yes the 9" lift is optional
You have the option of not fitting the tyres, or the 4.5" lift
That install said, only the lift, and tyres (31" tyres measuing 30") installed.
As per the reliability
He had 1 shock fail early on, and had to swap out the rear springs, or use bags of sand.
So that seems shit
Brake lines were snagging on springs
+1 on the shitty scale
He had to use washers to add width to all the bushes.
Right up there in the overall dodgy/shittyness.
Looks like there will be some good spring bind, so extra shit factor
The spacer on the strut is super dodgy.
That bracket on top of the diff (which replaces the factory ball joint bracket) appears poorly designed, offering very little rigidity.
Both these solutions are shit too.
That seems like a steaming pile of crap for US$2349
Post Posted: Wed Mar 16, 2016 10:04 am
FORWARD:
Date: 03/15/2016 08:30 PM
To: info@zukination.com, rjjjjj6@excite.com
CC: william@lowrangeoffroad.com
Subject: 4.5 Inch 1st Generation Suzuki Suspension Lift
To Whom It May Concern at Zuki Nation or Altered Ego Motor Sports:
#1. There's some negative comments about your 4.5 Inch 1st Generation Suzuki Suspension Lift at the following email thread:
viewtopic.php?f=5&t=52138
#2. What's your response????
#3. Why don't you join the email forum & answer directly????
Post Posted: Wed Mar 16, 2016 10:42 am
Subscribed for the lol's pompoms
I've had reasonable success Australianising the calmini kit & a decent bodylift. :wink:
Post Posted: Wed Mar 16, 2016 10:50 am
"Gwagensteve" &/or "jdk81" &/or "got_bar_work":
How would you compare Calmini suspension items with Zuki Nation suspension items overall?:
Calmini 1st Generation Suspension Systems including 1 kit for the 1.8 Liter Sidekick Sport or 2.0 Liter Vitara if you scroll to the bottom:
http://www.calmini.com/model.php?m=5&b=2&t=1
Calmini 1st Generation Suspension Components:
http://www.calmini.com/model.php?m=5&b=2&t=2
Zuki Nation or Altered Ego Motor Sports 1st Generation Suspension Items:
Post Posted: Wed Mar 16, 2016 4:00 pm
I'm no great fan of Calmini, but their front arms are OK. Their springs are OK if the rates work for you, their shocks and struts are garbage, as is the rear heim joint and bracketry, and they still can't drill metric holes.
However, despite all this, it has been approved for road use in all states of Australia.
I don't believe that will be possible with the altered ego lift, as it pretty much violates every principle an engineer will apply to pass a car for road use.
Post Posted: Wed Mar 16, 2016 9:58 pm
Same Altered Ego 4.5" lift install project, but again, a different email thread with some different pictures & comments:
http://www.zukiworld.com/forum/suzuki-s ... #msg259399
Post Posted: Thu Mar 17, 2016 7:02 pm
I'm interested as to what your motivation is. Posting "notifications" in a heap of threads (by the same guy?) are you just attempting to create a beef or what?
It's a garbage kit that is impossible to make legal due to all the hack engineering. If you want one buy it and work it out for yourself, but it's a bad idea.
Post Posted: Thu Mar 17, 2016 8:32 pm
My first thought following his post about the email to the manufacturer etc was "are you five?"
Then i considered perhaps he just wanted to actually engage the manufacturer and distributer in an intelligent discussion, which would be interesting.
Considered he has a vested interest in it.
Perhaps trying to open up a market here by creating some interest.
If so, very wrong target audience. Try facebook, there's way more stupid on facebook, but few will part with US$2349.
Mostly think hes just trying to cause trouble.
Post Posted: Thu Mar 17, 2016 10:03 pm
He's good at searching... I reckon it's Grimbo!
Vehicle: Which one?
Post Posted: Thu Mar 17, 2016 10:15 pm
FORWARD:
Date: 03/17/2016 10:42 PM
To: grimbo@grimbonation.com
Subject: Grimbo search
To Whom It May Concern at Grimbo Nation or Grimbo Motor Sports:
#1. There's some negative comments about your search.php capabilities at the following email thread:
Post Posted: Fri Mar 18, 2016 2:32 am
#1. I'm just trying to get a variety of opinions.
#2. Another disadvantage might be that extending the wheel base might enlarge the turning radius.
#3. One advantage to an American in the USA right now might be that 1 American dollar is worth about 1.3 Canadian dollars, or $1 USA is worth about $1.30 Canadian.
Post Posted: Fri Mar 18, 2016 6:11 am
The exchange rate doesn't make a bad kit a good kit.
Post Posted: Fri Mar 18, 2016 7:50 am
Id expect that to approach $4000 here after shipping and customs etc.
While the exchange rate isnt great, looking at median household incomes US $50k, AU $80k.
The delivered product would be about 5% of yearly median household income in both countries.
So the exchange rate/fiscal argument for us to dislike the kit is irrelevant too.
Post Posted: Sat Mar 19, 2016 12:15 pm
RJ6, you certainly have a "unique" style of forum posting.
Post Posted: Mon Mar 21, 2016 2:57 am
So unique in fact, that I have been able to recognize him in other for a where he posts as a different user - I can't help but wonder what his mission in life is - SPAMmer? Troll?
Post Posted: Mon Mar 21, 2016 6:48 am
Perhaps rj6 can give use some personal insight into his experience with lifted vitaras?
Post Posted: Mon Mar 21, 2016 12:54 pm
:rofl:
Users browsing this forum: Google [Bot] and 333 guests
