It is currently Thu Oct 22, 2026 12:45 pm
Vehicle: SJ70 Tintop, SJ51T, 97 Coily
Post Posted: Wed Mar 16, 2016 7:30 am
Fitted a transfer with a kong mount and it must have moved the box slightly back as the stick boot puts a bit more tension on the stick and makes it pop back out of low 4. Works fine with the boot removed and is not touching the body at all, its just the rubber boot causing the issues. Apart from cutting the boot is there any other boot I can use that is slightly bigger or more flexible. I dont really want to cut it to let in more noise and heat.
cheers
Vehicle: multiple R32's, wtd sierra
Post Posted: Wed Mar 16, 2016 5:40 pm
mine does the same thing from my body lift, i haven't bothered to find a solution yet so i'm keen to see what you come up with
Post Posted: Wed Mar 16, 2016 7:20 pm
Mine did that on the SJ410 farm bomb. I ditched the rubber boot and made one out of black felt. Its not the prettiest thing but you barely notice it.
Post Posted: Wed Mar 16, 2016 8:36 pm
Might work upside down I reckon and at least you still get the benefit of it closing up the hole proper
Post Posted: Thu Mar 17, 2016 8:42 am
It's simple enough to bend the stick slightly to get it to it more centered on the hole.
Or hammer around the opening of the hole in the top of the tunnel to give more space for the boot to bunch up more.
Post Posted: Thu Mar 17, 2016 7:41 pm
The boot sits inside the car and bolts to the floor, might end up bending the stick I think
Users browsing this forum: BZOOK and 137 guests
