It is currently Sat Oct 24, 2026 12:41 pm
Vehicle: 2001 M15A Jimny
Post Posted: Sat Mar 26, 2016 10:16 pm
Quick question:
On a scale between 1 and "you're a complete tool" how much of a f*** up have I made by using 'Shell gadus s2 v220 2' grease in my front CV joint? (Only did one side today)
Clicky for grease specs.
I replaced the inner axle seal and kingpin bearings and then realised I only had that grease and wheel bearing grease (which I know definitely not to use).
Post Posted: Sun Mar 27, 2016 11:37 am
You won't of damaged them mate, just check it is okay to use on the packaging for hightemp stuff and if not repack it. Wheelbearing grease, general non mineralized grease is usually alright
Post Posted: Sun Mar 27, 2016 12:35 pm
Thanks for the reply.
It's a lithium mineral grease. What sort of temperature are we talking? -20°c to +130°c apparently
Post Posted: Mon Mar 28, 2016 7:22 pm
Yeah if its between those it will be fine man, you should always be able to put your hand on the hub, so as a rough guess you are well within your limits.
Post Posted: Mon Mar 28, 2016 8:00 pm
Good! I just did the other side with it :D
The kingpin bearings were feral, congealed lumps of rust.
Users browsing this forum: Google [Bot] and 155 guests
