It is currently Mon Jul 27, 2026 10:45 pm
Post Posted: Fri Apr 01, 2016 9:53 pm
As title states, just put in a used transfer with 6.5's. Put gear stick into 2wd and holds fine. Between 4wd H L its very sloppy and it doesn't hold in either gear, like it doesn't click into gear.
Before I pull it down, anything obvious I should be looking for or seeing. The gears themselves seem fine.
Vehicle: Suzuki Jimny
Post Posted: Sat Apr 02, 2016 6:40 am
It's prob just the bush. Get one from Bruce or wait a couple of weeks and we will have some in the AZ shop
hillbilly 2 wrote:
And this ^^^^ clown is why auszookers will never be taken seriously
Vehicle: Drover pickup turk
Post Posted: Sat Apr 02, 2016 7:42 am
If it's not the bush, I'd say it's missing a detent ball or spring.
I like the tuna here
Post Posted: Sat Apr 02, 2016 8:26 am
This.
Vehicle: 2020 Vitara Turbo
Post Posted: Sat Apr 02, 2016 4:16 pm
Currently got the same problem, got new indent balls through SuziStore.
I've got a small breakdown but doesn't show this end, and the workshop manual I have on pdf doesn't show transfer case breakdown, would anyone have a copy for SJ413 to show the front of the case please ?
edit : part numbers where :
06111-10003G BRG BALL DETENT 7.9mm - need 3.
06111-12004G BRG BALL DETENT 9.5mm - need 1.
Thanks.
Post Posted: Sat Apr 02, 2016 4:17 pm
I have the a bush benny ill send you and i bet i have a denten ball too let me know if you want em
Or as board i can fix it for you the Thursday before coffs man
Post Posted: Sat Apr 02, 2016 4:45 pm
Thanks guys and my money is on dented balls. Great if you could Josh before the Coffs trip all though drove Carnage Trail like this today no dramas
and loving the 6.5's over the 4.9's
Post Posted: Sat Apr 02, 2016 6:03 pm
I don't see the issue with that?
BTW, dented balls sounds really painful!
Post Posted: Sat Apr 02, 2016 8:51 pm
If wilso doesn't have any detent balls I might have spares.
Users browsing this forum: No registered users and 309 guests
