It is currently Wed Oct 21, 2026 5:47 pm
Vehicle: 92 lwb vit
Post Posted: Mon Aug 29, 2016 7:57 am
Hi guys,
Drove my car up to work (adelaide to roxby) and now it will not start. Every now and again it would play up and I would have to go back and foward between park and neutral a couple of times and eventually it would start. This time it will not start at all.
My reverse lights do not work either and the globes are sweet so I am assuming
that there is a build up of gunk or something somewhere down there.
Is there a sensor/electrical plug that I can clean underneath the plastic base around the bottom of the shifter to get my motor started and my reverse lights working again?
What should I clean it with?
Thanks in advance guys.
Lamens terms would be appreciated, I am far from an auto electrician/mechanic.
Post Posted: Mon Aug 29, 2016 9:52 am
its the neutral safety switch (NSS), very similar to a jeep xj one.
http://go.jeep-xj.info/HowtoNSSrebuild.htm
Post Posted: Mon Aug 29, 2016 9:56 am
Nice link Jon. I think this is a common problem with Vitara aw-4's due to distributor housing leaks covering them in oil.
Vehicle: 92 lwb vit
Post Posted: Mon Aug 29, 2016 10:12 am
Thanks Jon. Hopefully I get a couple of hours to sort it out soon. Damn 12 hour shifts.
Post Posted: Mon Aug 29, 2016 10:14 am
no worries, it is a common thing for the reverse lights to not work, sometimes it takes a little jiggle of the shifter to get them to work.
Vehicle: 92 lwb vit
Post Posted: Mon Aug 29, 2016 10:30 am
https://youtu.be/70m0Pu6ZJ_0
These transmissions are the same yeah??
Post Posted: Mon Aug 29, 2016 10:39 am
not 100% the same but very very similar
Vehicle: 92 lwb vit
Post Posted: Tue Aug 30, 2016 4:12 am
Think its off to the mechanic. I had a go of fixing it myself, but with the limited tools I have and the transmission cooler lines in the way of the main nut. It was all a bit difficult on the driveway. Couldnt get the bolt moving. Mind you it was pourinf down with rain, so I may have another crack tonight if the weather is nicer.
Vehicle: 92 lwb vit
Post Posted: Tue Sep 13, 2016 8:33 am
Thanks for everyones input on this. Cost $80 for mechanic to fix. Limited tools up here mean it was buying axle stands and tools which i have at home or taking to mechanic. Reverse lights work. I am stoked.
Users browsing this forum: No registered users and 180 guests
