It is currently Sat Oct 24, 2026 10:27 am
Post Posted: Thu Sep 01, 2016 8:01 pm
Hi folks!!
Sierra;
Just wondering if Hubs, steering knuckles, brakes etc are compatible between NT and WT?
I have a set of NT everything front and back but looking at upgrading to WT. I can get hold of a WT diff and axle housings bare, but want to make sure all the outer parts will still fit.
Clearly I'd need to replace axles themselves for WT ones or Chromos, what else wouldn't transfer?
Worth noting I'm also putting a BenT rear disc brake kit on.
Cheers all!
B)
Post Posted: Thu Sep 01, 2016 8:31 pm
Yes, front is all compatible. Rear brake backing plates are different (bearing retainer is 45˚ out, linings etc are different), but you're sorting that out with the disk conversion.
I think I have 1.0 hubs etc in my front end!
Post Posted: Thu Sep 01, 2016 8:36 pm
Sweet!!
Thanks Steve!!
Also looking at Chromo axles. Now they are 26 splines if I'm not mistaken?
What are my options for diffs? I was going to put in air lockers later but perhaps I need to do this sooner?
If I'm understanding this correctly two rear diffs would work, or if I put in ARB air lockers would I need to put in two rears? Or change spider gears?
I really have no first hand experience with these setups
Vehicle: LWB Sierra
Post Posted: Thu Sep 01, 2016 8:58 pm
To fit cromo axles in the front, you have to have 26 spline side gears. Most people just put a rear centre in which is obviously 26 spline.
Does anyone know if coily knuckles are also compatible with WT diffs?
Post Posted: Thu Sep 01, 2016 9:00 pm
So would two NT rear diffs work? Are they 26 spline as well?
What about air lockers, which parts to they replace?
Post Posted: Thu Sep 01, 2016 9:14 pm
All Sierra rears are 26 spline and the fronts are 22. 2 NT rear diffs would work well, unless you want the taller WT diff ratio. You can put an airlocker in a 22 spline front diff to turn it into a 26 spline, it replaces the actual centre (not the whole 3rd member assembly, which many people call the centre).
If you want a locker then I'd get an airlocker and put it in the front 3rd member, put that in the back (giving you a rear locker with very little gear wear) and put your old rear 3rd member in the front. That way you wont have to swap the NT tailshaft yokes for WT ones too.
You can even bolt early 1l front drums onto a WT housing, I don't think anyone wants to do that though!
Post Posted: Thu Sep 01, 2016 9:30 pm
Thanks for that!! I was considering going twin locked but perhaps that's a more sensible option for the short term :)
Post Posted: Thu Sep 01, 2016 10:31 pm
Ok, so gearing.. I'm still trying. To get my head around a few things.
I haven't committed to a tyre size yet, but was thinking around 235/75R15.
I have 4.16 TF case gears.
I have NT diffs which are 3.9 ratio (if I'm correct), as opposed to 3.7 WT ratios.
Any suggestions on which would suit to bring gearing back to factory? Adjust tyre size or track down WT diffs?
Edit: I'd prefer to keep to a common tyre size rather than some obscure size
Vehicle: 92 Suzuki Sierra
Post Posted: Thu Sep 01, 2016 10:42 pm
i'm also curious about the speedo cable output of the transfer cases. Can they be swapped around and would this correct speedometer reading if diffs are swapped?
I know its a small difference but when you got the parts out why not?
Post Posted: Thu Sep 01, 2016 11:22 pm
Good going Santos!! I too am curious
Post Posted: Fri Sep 02, 2016 12:06 am
So taking a stock SJ51 with FR78 tyres (27.3"), 3679rpm at 110.
With 4.16s and 235/75r15s (28.9") 3897
With 4.16s, 235/75s and WT diffs (3.727) 3716
4.16, 30s 3.909 3754
4.16, 31s 3.909 3633
FWIW a stock SJ70 is 3962@110
Post Posted: Fri Sep 02, 2016 12:18 am
Sounds like the NT diffs, 4.16's and 235/75R15's would work ok.. It's a bit of an increase in revs but not drastic.
Even with the air lockers I should be able to swap to WT ring and alter the gearing slightly later on right?
Post Posted: Fri Sep 02, 2016 12:21 am
Yep. :)
Post Posted: Fri Sep 02, 2016 12:41 am
Your a legend mate!! Cheers!!
Post Posted: Fri Sep 02, 2016 7:13 am
In my opinion it's too costly to bother swapping r&p between 3.7 and 3.9 (new crush sleeves and professional setup will cost circa $300 per diff) and I'd almost guarantee you couldn't pick the difference, especially offroad.
Run whatever is in better condition.
Speedo ratios are the same for all models as far as I know. That's the reason there is a small difference in diff ratio between NT with 27.3" tyres and wt with 26" tyres. I can't recall revs/km at the moment but it's marked on the speedo and is the same for nt and wt. (it's 637 revs/km or something)
Vehicle: 2020 Vitara Turbo
Post Posted: Fri Sep 02, 2016 7:16 am
Bumstein I've got a set of 3.7s ring n pinions if you get stuck too, also a set of 3.9s. Took them out of both cars to go 5.12s.
Post Posted: Fri Sep 02, 2016 8:46 am
I ask more for when buying second hand parts when available & cheap. Good point on the speedo I will check and confirm my 85 and 92.
Would you say there was no point putting 4.1 diffs on an NT? its only 0.2 difference as well
Post Posted: Fri Sep 02, 2016 8:55 am
Not much point. (It is 5% though, not 0.2%)
Post Posted: Fri Sep 02, 2016 9:12 am
i didn't put a percent sign 4.1-3.9 = 0.2 ;)
Post Posted: Fri Sep 02, 2016 9:45 am
Thanks mate! Will have a look tomorrow :)
Users browsing this forum: No registered users and 91 guests
