It is currently Mon Jul 27, 2026 7:46 pm
Vehicle: 1992 suzuki sierra hardtop
Post Posted: Sun Oct 23, 2016 8:38 pm
iv been told that an 85 paj tank will fit is this correct?? i need a new tank in my lwb and cant find one!!! i all ready know the swb is the same but the pipes are different and no body around here will change them :evil: :evil: :evil: :evil:
Post Posted: Sun Oct 23, 2016 8:53 pm
Any number of tanks will fit if you move the mounts (which you'd have to do). SWB vitara goes in easy behind the rear axle.
Post Posted: Sun Oct 23, 2016 9:26 pm
Jackaroo tank fits behind the rear axle with custom mounts. 88L IIRC.
Pretty sure long ranger or one of those mobs still do a bolt in long range tank.
Post Posted: Sun Oct 23, 2016 9:38 pm
Yeah long ranger do but its for the swb.. I'll just have to modify one by the looks of things.
Post Posted: Sun Oct 23, 2016 9:42 pm
100% I was looking it up maybe 6 months ago and someone was selling one specifically for the midmount factory trayback tanks.
Post Posted: Sun Oct 23, 2016 9:44 pm
There hard to find lol
Vehicle: SJ51T
Post Posted: Thu Nov 03, 2016 7:01 pm
U could make an ugly one and regret ur design after all ur hard work like i did
Vehicle: LWB tray top G13B
Post Posted: Thu Nov 03, 2016 8:01 pm
For people with tanks behind the axle, wheres your spare wheel? (Lwb)
Post Posted: Thu Nov 03, 2016 9:03 pm
In the shed at home, where it belongs.
Post Posted: Fri Nov 04, 2016 7:35 am
Pretty rare ya need a spare on a Zook claytox... I haven't had a flat tyre yet and Iv had zooks for 10+years
Post Posted: Fri Nov 04, 2016 7:53 am
The factory under tray spare mounts fail and the spare falls out anyway. See, even Suzuki knew you didn't need it.
I joke, but I have almost 25 years of Suzuki experience. I've never seen an unrepairable tyre failure.
Post Posted: Fri Nov 04, 2016 11:14 am
Still no luck with a tank
Post Posted: Fri Nov 04, 2016 4:44 pm
I tore a valve stem off on a rock. That was pretty unrepairable trackside.
Post Posted: Fri Nov 04, 2016 8:49 pm
Not at all. Sure, it takes a little time and some tools but it's completely repairable.
Post Posted: Fri Nov 04, 2016 9:55 pm
Steve is right. Unless you have a giant gapping hole in your rubber most stuff you can fix if you have the right kit
Post Posted: Sat Nov 05, 2016 8:05 am
The aldi $20 ki
Post Posted: Sat Nov 05, 2016 10:41 am
Ok, so it's repairable. But it's a lot less effort to put the spare on.
Post Posted: Sat Nov 05, 2016 11:45 am
Sure, but carrying an impractically heavy and bulky spare because it's easier that repairing a valve stem or reseating a bead doesn't make sense for tiny cars that are so payload limited.
Example - a full sized spare on my car would require me to carry almost nothing else in my car, and it weighs 50Kg. So I carry tyre levers, spare valve stems/cores, and plug kit.
Interestingly, I've never required any of it for my own car. I did recently break off a high-flow valve stem, but as these are threaded, I removed it and threaded in a plug. I didn't need to remove the tyre (or even the wheel from the car)
Post Posted: Sun Nov 06, 2016 5:58 pm
Fixed it with a heap of 50-50 solder hopefully it won't leak again!!
Users browsing this forum: Google [Bot], shep and 394 guests
