It is currently Fri Jul 24, 2026 9:14 pm
Post Posted: Thu Sep 24, 2009 2:48 am
Hey guys,
my tyre valve seem to be dropping pressure pretty quick (from 28psi to 9psi in less than a week)
What are a good type of valve to replace this crapy ones with?
and how easy is it to change them?
thanks
99 Jimny mods on the way!!!!1
Vehicle: Nissan
Post Posted: Thu Sep 24, 2009 2:53 am
valve or valve stem? take it to a tyre shop and get them to do it or you will need a valve tool to replace the valve. or a valve puller to replace a valve stem as well as a bead breaker.
Pearce-toff Racing
Post Posted: Thu Sep 24, 2009 3:38 am
PM Atari, he collects them
Vehicle: 1999 Jimny
Post Posted: Thu Sep 24, 2009 9:16 am
If ya doing lots of wheelin' then keep rubber valve stems in.
Vehicle: MY2019 Jimny
Post Posted: Thu Sep 24, 2009 10:42 am
Yeah you will need a genuine cap.
Post Posted: Thu Sep 24, 2009 12:15 pm
just an idea iv had the short atv valve stems fitted coz with the standard size valves, mud seems to tear out and put pressure on them. Bolt on metal ones solves the problem but if rocks hit them they break off. Iv got access to direct tyre supplies if enuf ppl are interested i can get some. I think they are about $2 each...
Post Posted: Thu Sep 24, 2009 2:29 pm
I've got the short ones on mine too, heaps better!!
Post Posted: Thu Sep 24, 2009 3:01 pm
it's valve caps i collect...
you could be onto something, i never thought about collect the actual valves!!
Vehicle: SJ80, SE416
Post Posted: Thu Sep 24, 2009 5:08 pm
jimny_99 wrote:
Hey guys,
thanks
My 2c,
Would it be valves (how do you know it's the valves), or is it more likely to be a leak from dirt in the bead? Just go to a tyre shop and have your tyres checked over.
Reubs.
Post Posted: Thu Sep 24, 2009 10:59 pm
I got them to :wink:
Post Posted: Mon Sep 28, 2009 7:36 pm
Are the valves tight in the stem, some people think it's funny to loosen them, check this first otherwise it may be dirt in the bead of the tyre if you've been wheeling.
Users browsing this forum: No registered users and 762 guests
