It is currently Sun Jul 26, 2026 6:10 am
Vehicle: 93 Sierra
Post Posted: Tue Dec 27, 2016 10:05 pm
Bit of a nooby question but my starter motor is stuffed and I don't have time to strip it down and recondition it, so I need a new one. Pulled the old one out and the part label is pretty torn up so I'm not sure whether it's 0.8kW or 0.9kW - but the FSM says it's important to match what's currently fitted.
I'm guessing it's probably a 0.8kW as it looks the same as the 0.8kW fat body 1.3L starters with non-threaded holes available on eBay (eg this one), but can anyone confirm that based on what's left of the label or the starter itself?
Post Posted: Wed Dec 28, 2016 5:00 pm
I doubt it will matter. Its a mitsubishi Starter motor. They are all similar if you find one with a fat body.
I now have newer mitsu mirage internals in my sierra housing as its machined/ground down for a 1.6 block. Same internals. Same brushes. Similar solinoid.
The only main difference is a more offset alloy housing section for the solinoid.
Hyundai excel are similar again(copy) but korean.
Post Posted: Wed Dec 28, 2016 8:07 pm
Hey Tim i have a starter here with 31100-8303 on it out of my coily it only came out cause the G16B went in then had to run a skinny starter.
It's yours for free if ya want it
Vehicle: 93 Sierra
Post Posted: Wed Dec 28, 2016 9:50 pm
Cheers Joe - I'm going to order one of the cheapy eBay ones cos it's new 'n shiny but if it doesn't fit or something I'll sling a case of your favourite frothy beverage your way for yours :)
Thanks BlueSuzy for the info.
Users browsing this forum: No registered users and 40 guests
