It is currently Wed Oct 21, 2026 9:32 am
Vehicle: MR2
Post Posted: Mon Mar 13, 2017 5:54 pm
GV 2005 V6 2.5 5 door Auto.
This started about a month ago. After 40km/h you start to hear very faintly a rapid clicking noise. As you build up to 100km/h the sound gets louder. The sound is noticeable but its not piercing. This clicking noise is coming from under the Auto Transmission Lever. At the same time as the clicking noise it sounds like air is being let in underneath there. A constant "whoosh of air" sound - no whistling. The clicking sound is louder than the whooshing sound. If I stick it in Neutral at 80KM/H, the noise continues.
I took it to the mechanic for a regular service and he thinks there is no issue. Just standard sound but its not. He said he took a look underneath and didnt notice anything.
While the transmission oil looks fine, I do want to get it replaced as well as the filters. Its done 180k kms and it may never have been done before. I am not sure if this will resolve the issue.
There is no drop in performance or other noises.
My next step is to try and pull the plastic surrounding the Lever to see if I can pinpoint where the sound is coming from.
Anyone seen something similar?
Vehicle: Suzuki Grand Vitara 04 manual
Post Posted: Tue Mar 14, 2017 12:44 pm
1. Classic zip tie prank. Zip tie around the prop shaft, OR
2. Rubber seal on the shift leaver has come loose, flapping with increased speed and sucking air from pressure diff, inside low pressure outside high pressure. Pull apart the centre console like you suggest. That's my guess too.
Vehicle: MR2
Post Posted: Tue Mar 14, 2017 12:55 pm
Had a quick search and didnt come up with much info around how to remove the center console where lever is. Any pointers?
Post Posted: Tue Mar 14, 2017 1:45 pm
Can you record the sound?
From my experience, the autos make a funny sound, chattering type sound, which is much worse when in OD, then they lose reverse.
No idea how long it takes from the chattering to losing reverse.
Vehicle: MR2
Post Posted: Tue Mar 14, 2017 2:00 pm
I can try. But let me pull console out first and see if its something simple. At least if I cant figure it out, the sound should be loud enough to record.
I never use OD but the sounds continue the same in OD and ATPower. I am not looking forward to replacing or repairing the transmission.
Vehicle: MR2
Post Posted: Sat Mar 18, 2017 3:38 pm
Heres a few pics of in and out of the car. Maybe it might give someone else an idea as to what it could be...
A bit stuck. I feel around with my finger when driving and cannot feel any air come through. Its definitely around the lever vicinity (or closer to the ground) that the clicking noise is coming through.
I will try and get some audio later today or tomorrow.
Users browsing this forum: No registered users and 112 guests
