It is currently Thu Oct 22, 2026 4:08 am
Vehicle: 2002 suzuki jimny
Post Posted: Thu Apr 13, 2017 7:46 pm
Has anyone replaced jimny front hub bearing with opposing tapered roller bearings as I bought a replacement kit when I opened kit the bearing was not ball bearing like standard but tapered roller pin bearing. The problem I have is bearing box had already been open greasy prints over the lid I asked where I bought them he thought I didn't know rollers when I saw them hard to miss look like king pin bearings type but 2 rows apposing same size. thanks again
Vehicle: GV1600SE-2005
Post Posted: Fri Apr 14, 2017 2:52 am
2 tapered roller bearings is the normal for a front wheel bearing. The Jimny uses a 3 piece unit, outer race and 2 inner races complete with rollers.
Post Posted: Fri Apr 14, 2017 7:26 am
Well I looked in the workshop manual and it shows ball bearings, but when checking photos of the hub bearing most show tapered roller type. Maybe it just depends on the bearing manufacturer.
Post Posted: Fri Apr 14, 2017 8:27 am
Sounds like they sold you sierra ones.
Jimny use a cassette, which i think its the same as vitara.
Post Posted: Fri Apr 14, 2017 10:02 am
Some early jimny ones are seperate tapered but most are cartridge
Post Posted: Fri Apr 14, 2017 11:43 am
The tapered bearing prob won't like being done up to the torque that is in the jimny fsm.
I don't know this for sure but I have never seen a tapered bearing done up to 220flb
Post Posted: Fri Apr 14, 2017 7:05 pm
Just a bit of info put together. The cartridge ball type is standard Suzuki Jimny fitment. Many of the aftermarket bearing suppliers show this bearing as a taper roller cartridge. This is standard Suzuki Vitara fitment, I would think this would work fine in the Jimny
Post Posted: Sat Apr 15, 2017 9:16 pm
Thanks for info but has anyone used them and what torque did you do them up to , I think they are designed to bottom out with correct clearances.
What type of grease do you use for cv and pivot bearings moly or blue sticky type grease
Users browsing this forum: No registered users and 183 guests
