It is currently Sun Jul 26, 2026 7:10 am
Vehicle: 1995 Suzuki Sierra SJ70
Post Posted: Sun Jun 18, 2017 2:54 pm
Going through steps in FSM for Baleno SY416, to remove G16B motor. It's a 2WD MT car.
I'm nearly there but:
Cannot find the clutch operating cylinder. Do I have to remove this?
Cannot locate the propeller shaft in order to disconnect it. I feel pretty stupid but I can't see it there anywhere. It's supposed to be on the transmission case flange.
Help would be appreciated.
Dave
Post Posted: Sun Jun 18, 2017 5:38 pm
Driveshafts run to each front wheel and from memory they just pull out (circlips) can't recall where the clutch runs to, but it will be on the bellhousing, so on the LHS of the car down low.
Post Posted: Sun Jun 18, 2017 5:47 pm
Dave
Clutch is cable, The last one i did, Just cut the axles with a grinder. They are made of cheese
Post Posted: Sun Jun 18, 2017 5:57 pm
Thanks for the answers, I was in a mad rush to get the Baleno engine out by dark (I'm working outdoor / not undercover) and I only had use of the crane until the end of today. I think it must be a cable type clutch so there is no hydraulic system. As for the propeller shaft, still a bit confused about that, but as you were saying if I can remove the driveshafts then that should take care of it. Ran out of time, but I can get the crane back soon so I'll get to take another look at it next weekend.
Post Posted: Sun Jun 18, 2017 6:00 pm
I'm a bit confused about the use of the term "propellor shaft"- I suspect it's referring to the short shaft that runs from gearbox to the drivers side CV, so it runs beside the sump.
Can't recall what it attaches too.
Post Posted: Sun Jun 18, 2017 6:23 pm
Here is a screen shot from the FSM:
Post Posted: Mon Jun 19, 2017 12:49 pm
You have the wrong manual. That looks like a jimny rear shaft
Post Posted: Mon Jun 19, 2017 7:07 pm
I've been working out of a this baleno manual, pages 315 - 318 apply to engine removal.
https://docs.google.com/viewer?a=v&pid=sites&srcid=ZGVmYXVsdGRvbWFpbnxzdXp1a2lidWlsZHBob3Rvc3xneDo1ZGVhMDE3YWVjZjlhMWM
Vehicle: Drover pickup turk
Post Posted: Mon Jun 19, 2017 7:40 pm
I like the tuna here
Post Posted: Mon Jun 19, 2017 11:07 pm
Balenos were available AWD - that diagram shows the "propeller shaft" on the AWD version, your 2WD vehicle won't have one.
Post Posted: Wed Jun 21, 2017 6:45 pm
Yes, you're right fordem I should've twigged sooner.
Usually FSMs say "ïf equipped" for non standard options but not in this case, so I wasted quite a bit of time trying to work that out.
Frustrating, as I was trying to get the motor out by the end of Sunday.
I'll be better prepared when I have another crack this Friday.
Post Posted: Fri Jun 23, 2017 8:38 am
Got back under the Baleno this morning to remove those driveshafts.
After knocking the joint apart with a hammer no clips to be found :?
Must be a different type of drive shaft.
Post Posted: Fri Jun 23, 2017 12:51 pm
No problem, drive shafts are now disconnected.
Users browsing this forum: Google [Bot] and 31 guests
