It is currently Sat Jul 25, 2026 8:06 am
Post Posted: Sun Sep 27, 2009 1:35 am
I`ve heard it said thay fit, would this be std Gv springs to give lift?
I will have a spare set of 2inc lift Gv springs soon & was wondering if thay could go into a mate`s 2lt v6 wagon vit.
I`m thinking thay will be to stiff.
Any one?
Post Posted: Sun Sep 27, 2009 1:42 am
give it a shot, they couldn't be any stiffer than the calmini ones!
Post Posted: Sun Sep 27, 2009 1:44 am
I have lifted GV springs in my NT (tee hee) vit in the front and stock GV wagon springs in the rear (SWB), they probably are stiff but I'm used to stiff cars
good for about 40mm lift
Post Posted: Sun Sep 27, 2009 1:47 am
I know of the strut top flip, any thing else? My rear shoky`s should fit but doubt the strut`s will.
The Wt`s run the center wishbone on the rear to? I`ll have to space that, have I forgotten anything?
Post Posted: Sun Sep 27, 2009 1:50 am
I have OME and lots of travel but standard struts should still be fine with small lift (I reckon a v6 wagon would be similar weight to a GV anyway) rar shocks are pretty short anyway but not a lot you can do
I hate them fucking wishbone spacers, stupid idea
Post Posted: Sun Sep 27, 2009 1:53 am
What did you do with your wish bone?
I could get a bigger 1 made I suppose. Just trying to do it as cheap as possible for him...
Post Posted: Sun Sep 27, 2009 1:56 am
scroll down, something like this will be fine 8O 8O
http://auszookers.com/index.php?name=Fo ... c&start=30
:roll:
Post Posted: Sun Sep 27, 2009 1:59 am
my wishbone is as suzuki intended, I know it bottoms out 1 inch before the shocks do if the diffs drops evenly, if I am ever dumb enough to get that hung up I will worry about it then
Post Posted: Sun Sep 27, 2009 2:05 am
Thanks, i don`t think this fellow will have an issue with it then.
Your car is 1 I haven`t look at in rig`s, will do that now..
Post Posted: Sun Sep 27, 2009 2:06 am
not many pics in there, I am lazy :)
Post Posted: Sun Sep 27, 2009 2:14 am
Hey Steve, I've got a full set of stockies sitting in my garage if you want to take them and try it out?
If your not breaking shit, try harder!!!
Post Posted: Sun Sep 27, 2009 2:32 am
i will never sell these as people like to make dodgy shit
http://outdoorauto4x4.com/p/848569/vita ... pacer.html
Post Posted: Sun Sep 27, 2009 2:35 am
cause its $180 for a shitty piece of steel that has no benefit at all and fucks up your geometry
and its not a Heim joint its a ball joint, you wanna make money make a replacement arm with a real Heim of Johnny joint in it for $180
Post Posted: Sun Sep 27, 2009 2:40 am
:roll:
That`s rough... I`d prefer to make a new arm.
Post Posted: Sun Sep 27, 2009 2:41 am
Gv`s? you have a vit in pieces to, could see if the strut`s fit... 8)
Post Posted: Sun Sep 27, 2009 2:48 am
Yeah, GV's & that part of the vit is still together, but if you want to pull it apart, be my guest.
Post Posted: Sun Sep 27, 2009 2:50 am
Have you sold much off it yet??
Post Posted: Sun Sep 27, 2009 3:10 am
NAH, not much, I have a few people interested in the motor and bits and bobs and one guy interested in the whole car, but have only sold a cople of parts, but I have pretty much stripped the body. its hard to know how much to ask for and how much is too expensive, but I'm the one putting the work in so I dont just want to give it away.
Post Posted: Sun Sep 27, 2009 3:15 am
Hasn`t been up for long, see how it goes. At least you got the diff`s tho, mine are gathering dust till I get a front locker.
Post Posted: Sun Sep 27, 2009 3:18 am
cant you just put them staight in, cause thats what I pland on doing until the locker goes in. How far off getting the locker are you?
Post Posted: Sun Sep 27, 2009 3:26 am
Got a 2.5 calmini kit coming cheap, shock`s are stuffed so gunna replace them, then start saving for the locker.
I`ve only got small tyre`s so ratio isn`t as important as flex to me.. looking at early next year. Have a read through your diff thread & look at what joeblow said about the front diff, it`s not a straight swap.
Post Posted: Sun Sep 27, 2009 3:35 am
I think he's talkin about thr complete diff, I'm only doing the centres.
Oh shiiiit......I dont know what I'm doing, now i'm really confused...I thought I'd be able to slip my 4.3 centres out and bolt the 5.12's straight in.
Post Posted: Sun Sep 27, 2009 3:48 am
I did the same thing, I gather that you want to get rid of the vacc operated front? That`s when you need the sierra side gears ( i think ) the rear so i`m told will go straight in.
So if you leave the vacc in you change ring & pinion`s over.
With me? ( took me a bit ) :roll:
Post Posted: Sun Sep 27, 2009 3:59 am
Fuck me....you lost me at hello...think I might have to just take my 5.12's to ARB and say.... here, fit me a locker....
Post Posted: Sun Sep 27, 2009 11:19 am
I would think ditching the vac stuff and adding freewheeling hubs would be the go.
Post Posted: Sun Sep 27, 2009 3:29 pm
yeah you put the vit stuff in and fit freewheeling hubs, youll need to pull the vacuum line off the pump under the bumper and cap it so it can suck in and think the diff is locked when you put it in 4wd otherwise the light on the dash blinks
though I would get the gears fitted back into your steel stuff, youll smash the alloy bits pretty quickly
Post Posted: Sun Sep 27, 2009 4:04 pm
Didn`t know that about the vacc pump, thank`s royce!!
I was going to just use the switch to trigger a relay, light on Johny 8)
Users browsing this forum: No registered users and 235 guests
