It is currently Fri Sep 25, 2026 7:55 pm
Vehicle: 1.3 Sierra
Post Posted: Wed Aug 16, 2017 11:39 am
Hey everyone.
I have an 89wt sierra with a g16b (from x90)
It only seems to run on 3cyl.
Has spark to all 4. Has fuel to fuel rail. Timing is right.
I pull no.3 spark lead off and it doesn't change idle.
Just wondering where the logical place to look would be?
Cheers.
Post Posted: Wed Aug 16, 2017 12:24 pm
Have you tried changing the plug?
Is the injector firing?
Post Posted: Wed Aug 16, 2017 3:11 pm
Vacuum leaks are worth exploring for. I'm not familiar with the G16B but a vacuum leak can cause a single cylinder to misfire
Vehicle: 1.3 Sierra
Post Posted: Wed Aug 16, 2017 5:18 pm
Have swapped plugs around with no changing results
Not sure how to tell without pulling injectors out?
Will have a close look/test the vacuum hoses.
Thanks
Post Posted: Wed Aug 16, 2017 6:39 pm
Fuel filter, dirty tank
What fuel pump setup are you running ?
Post Posted: Thu Aug 17, 2017 10:38 am
you should be able to check the injector pulse signal on the injector plug with a test light to see if all are pulsing
Vehicle: 1.3 Sierra
Post Posted: Fri Aug 18, 2017 2:41 pm
Hesitates and backfires. Still no number three.
Vac hoses look ok.
In tank pump (coily maybe). New fuel and filter.
All injectors are pulsing. Could there still be blockage?
I think compression test next?
Post Posted: Fri Aug 18, 2017 2:59 pm
Does it run a crank angle sensor in the front of the sump ?
Post Posted: Sat Aug 19, 2017 12:16 am
Yes.
Post Posted: Sat Aug 19, 2017 8:21 am
Backfiring normally means timing related not fuel, if the motor runs a crank sensor then this could be the issue, coilpacks normally break down and hesitate but no backfiring
Post Posted: Mon Aug 21, 2017 11:23 am
depends if there is fuel getting to the exhaust unburned and then igniting
Vehicle: 1.3 Sierra
Post Posted: Mon Aug 21, 2017 4:01 pm
Not sure a crank angle sensor would isolate the problem to no.3 cyl?
Compression test is all good!
Guess I'll be pulling the injectors out. Is there any way to test on the bench? Or should i be taking them to a mechanic?
Post Posted: Mon Aug 21, 2017 4:14 pm
something like this maybe
https://www.youtube.com/watch?v=xvkRZWBG6vs
Post Posted: Tue Aug 22, 2017 7:44 am
Mine backfired and 'missed' like mad when the stems had died (leads, whatever) - At first it was just one of them, then suddenly it was un drive-able when the coil pack went and took out two cylinders.
While it's running, unplug each stem and see if there's one that makes no difference.. that'll help isolate it if it's them.
Post Posted: Tue Aug 22, 2017 8:08 am
already did this
Vehicle: 1997 2.0 JLX 3dr
Post Posted: Tue Aug 22, 2017 11:06 am
Move injector to another cylinder and see if the problem moves across.
Vehicle: 1.3 Sierra
Post Posted: Thu Aug 24, 2017 3:42 pm
Well i pulled it all apart and then put it all back together and she's running on all 4!
New problem! Starts fine, idles high (2500rpm).
Once warm, it surges quite fast between 1500 and 1800rpm.
What problems have others experienced resulting in these symptoms?
Post Posted: Thu Aug 24, 2017 3:46 pm
air in coolant lines to the throttle body.
Clean IAC valve
Post Posted: Thu Aug 24, 2017 4:16 pm
Id try find a complete throttle body to swap and iac
Post Posted: Thu Aug 24, 2017 4:32 pm
its been sitting for a while so im betting on a sticky IAC
Post Posted: Thu Aug 24, 2017 5:01 pm
I never have much luck just cleaning the iac always seem to end up swapping the whole assembly over as a fix
Vehicle: 1.3 Sierra
Post Posted: Thu Aug 24, 2017 5:03 pm
Yay bit of wax and grease remover and paint brush iac and throttle valve and she purrs like a kitten!
Vehicle: 1.3 Sierra
Post Posted: Thu Aug 24, 2017 5:04 pm
Thanks all.
Post Posted: Fri Aug 25, 2017 8:07 am
Result!
Post Posted: Fri Aug 25, 2017 5:18 pm
How exactly is the IAC cleaned ? And how do I remove it. On a baleno g16b ? Cheers
Vehicle: 1.3 Sierra
Post Posted: Fri Aug 25, 2017 9:50 pm
Will take a pic tomorrow.
Post Posted: Fri Aug 25, 2017 10:02 pm
Legend Thanks mate
Vehicle: 1.3 Sierra
Post Posted: Mon Aug 28, 2017 5:08 pm
Pull this off and use carby cleaner and toothbrush and clean throttle valve. There is also a little bypass valve that controls idle, clean this too!
Post Posted: Mon Aug 28, 2017 5:47 pm
Awesome thankyou my baleno motor looks abit different but I should be able to find that part aswell anyways
Vehicle: 1989 1.6 Suzuki Sierra
Post Posted: Sun Sep 05, 2021 7:07 pm
That’s just the TPS isn’t it?
IAC is under it with coolant lines attached?
Users browsing this forum: No registered users and 645 guests
