It is currently Fri Jul 24, 2026 8:12 pm
Post Posted: Sat Sep 26, 2009 11:46 pm
hey guys my engine swap is basicaly complete for some reason my starter motor is giving me troubles not sure why yet its just making a clunking noise but had it tested and is suposably fine :S. but the main problem is the fuel pump i took the fuel pump off and i have placed it back on and now its not pumping :S just wondering can any one explain how the pumps work and what moves the lever from what i can see i thought it was oil pressure that flowed into the pump moved the lever not sure though just a guess but if any one has any idea on how to fix it thanks luke
Post Posted: Sat Sep 26, 2009 11:48 pm
It`s a 8 valve? sounds like the push rod in the head fell out, have a look under the car.
Post Posted: Sat Sep 26, 2009 11:52 pm
hey thanks for the quick reply whats the push rod does it sit inside the little hole thsat sits up against the lever??
Post Posted: Sat Sep 26, 2009 11:58 pm
Yes. That`s the one! If that`s in you may not be geting the lever against it properly, thay can be temperamental.
Post Posted: Sun Sep 27, 2009 12:03 am
yeh nah ive lost the pin out of both engines can you explain what they look like so i can start my hunt for this pin thanks so much for the quick replys and help
Post Posted: Sun Sep 27, 2009 12:09 am
It`s just a small tubular piece om metal, Can`t remember how long.
bout 4-6 cm long from i think :roll:
Post Posted: Sun Sep 27, 2009 12:10 am
they are a short steel rod same diameter as the hole and about 40-50mm long
Post Posted: Sun Sep 27, 2009 12:12 am
ok awesome to the garage the search begins then i just have to fix the starter motor problem then im back out 4x4ing cant wait thanks so much guys
Post Posted: Sun Sep 27, 2009 12:16 am
got any pic`s of you car????
We like pic`s :wink:
Post Posted: Sun Sep 27, 2009 12:24 am
You interested in a wheel at the g'house. Check out my post in trips & travel. Good luck with the fuel pump mate. I found it easier to make sure the pin(moves on cam rotation)is out a fraction from its locating hole and locate the arm on the pin, put bolts in and do up from side to side gradually. Not sure how other blokes do it but it worked for me. Hope this makes sense and helps you out a bit.
Post Posted: Sun Sep 27, 2009 12:45 am
ok awesome i have a few at home ill put them up later and put up what shjes got and so forth for you guys shes just a stoko atm besides engine need the money but def keen for a run in the glass house mountains but i hope you like pulling me oput lol i only got road tyres atm as i said stoko lol. but yeah thanks for your help guys :D so glad i become a member of this site
Post Posted: Sun Sep 27, 2009 12:53 am
pompoms peaceout pompoms peaceout pompoms peaceout pompoms
Is that your 1st Suzuki??
Post Posted: Sun Sep 27, 2009 12:57 am
More than welcome mate...I know 1/10th of what some guys on this site, but i like to give feedback on the little i do. This site has helped me learn a lot already, it is excellent. Don't worry about the stoko thing you'll be alright. Don't be affraid of asking 'stupid questions either" I have, you may cop a bit of shit, but you always get the answer you need. :D
Post Posted: Sun Sep 27, 2009 5:10 am
yeh she is my first 4x4 ive gone form rice burner to my new zook and i absolutley love it :D and Rusho81thats awesome and thats what every one needs every one helps eachother its greatand i know about asking i been on a heap of forums before boost cruising and so forth but im keen to come for a run. but hopefully wont be driving my stoko zook much longer i got my shopping list sorted :D 2inch body lift, 2 inch suspension lift, 30"s or 31"s muddys, snorkle, roof cage. and happy days ill put pics up tomorow some time for you :D
Post Posted: Sun Sep 27, 2009 12:22 pm
Go 30's mate..less hastle, snugger fit. 31's can rub, not saying they will but can.
Post Posted: Sun Sep 27, 2009 3:42 pm
Talk to just-cruising for boby lift. link below.. 8)
http://www.auszookers.com/index.php?nam ... pic&t=6186
Users browsing this forum: No registered users and 607 guests
