It is currently Sat Oct 10, 2026 10:47 pm
Vehicle: 90 Lwb + 89 Swb
Post Posted: Fri Sep 29, 2017 4:01 am
The main filler neck on the Sierra metal fuel tank, would that take a 41mm or 44mm inside diameter hose?
My old tank was rotted so it is gone, and new tank has been ordered.
Thanks in advance.
Post Posted: Fri Sep 29, 2017 9:23 am
The filler neck measures in at 42mm
Post Posted: Fri Sep 29, 2017 10:54 pm
I'll go for the 41mm fuel hose.
Thanks!
Post Posted: Sat Sep 30, 2017 5:27 pm
Are you talking about the rubber hose that fits between the body and the tank? From memory it's a wider diameter at the body end.
Post Posted: Sun Oct 01, 2017 7:36 am
Yes, that is the correct hose...filler cap to fuel tank hose.
The body end I am modifying, so it is the tank end I am referring to for mm size.
I was aware it was a tapered hose, but thanks for pointing that out and looking out for me. :-)
Users browsing this forum: No registered users and 215 guests
