It is currently Sun Jul 26, 2026 5:51 am
Post Posted: Mon Sep 28, 2009 1:19 am
Today after a few beers I got motorvated enough to pull out my fuel tank to repair the dent that has lost me a good 5 litres of capacity. I was even motorvated enough to take a couple of pics and do a write up for the members that are new to pulling things apart and are lacking the confidence to do so.
The dent I wanted to repair
It would help to have as little petrol in the tank as possible before removing the tank. Ensure there are no naked flames or sparks anywhere in the vicinity of where you are working. Place a drain can under the filler hose, undo the clamp and remove the filler hose.
Post Posted: Mon Sep 28, 2009 1:24 am
Shit yeah that looks easy as !!!! :rofl:
Post Posted: Mon Sep 28, 2009 1:26 am
Remove the wire from the fuel gauge and the two hoses from the top of the tank. This is pretty straight forward if your car has a bodylift, but may be a bit of a pain if you don't. If this is the case loosen the four bolts that hold your tank in as much as possible without removing them completly, so you can acess the hoses. If the hoses are hard to remove try twisting them or butting a screwdriver up to the end of the hose and hitting the screwdriver with the palm of your hand.
Working from underneath the car undo the main fuel line from the pickup on the fuel tank. Use a 17mm and a 14mm spanner to loosen the pipe. Do NOT use just a single spanner on the pipe or else damage to the pick up line on the tank will result.
Post Posted: Mon Sep 28, 2009 1:31 am
Remove the 4 bolts that hold the tank in and remove the fuel tank from the car.
Refitting is a revesal of the above procedure
Post Posted: Mon Sep 28, 2009 1:35 am
Well how did ya remove the dent
TWIN LOCK IT & JUST DRIVE!
Smart arse :roll: :lol: As mentioned this was intended for the guys out there that have absolutly no experience in pulling things apart.
I'd do a write up on how I repaired the tank, but I don't want to be resposible for forum members blowing themselves up :lol:
Post Posted: Mon Sep 28, 2009 1:39 am
Pics of repaired tank
Post Posted: Mon Sep 28, 2009 1:41 am
:comeon: we wanna see it :twisted:
Post Posted: Mon Sep 28, 2009 1:48 am
well all I'll say is that it involved drinking a six pack, a spark, an explosion and a change of underpants.
The result is so impressive, I'm sure I not only got my lost 5 litres back, but I may have increased it's capacity too :lol:
Post Posted: Mon Sep 28, 2009 1:52 am
:youdaman: :rofl: :rofl:
Post Posted: Mon Sep 28, 2009 1:57 am
write it all up and put it in here: http://www.auszookers.com/index.php?name=News&topic=2
that way it is always in an easy to get to place, and royce can stop complaining that no one adds to it :D
Post Posted: Mon Sep 28, 2009 2:18 am
thanx for that. Done
Post Posted: Mon Sep 28, 2009 2:24 am
Wasn't trying to be a smartass.... Just that when I posted it looked like that's all there was to it.... :wink:
Post Posted: Mon Sep 28, 2009 2:28 am
I figured somebody was going to reply whilst I was in between posts. It's hard to type and eat trifle at the same time ;)
Post Posted: Mon Sep 28, 2009 3:34 am
hhmmm, silly qtn time, how do you add things into that area? Just had a looksy, but i cant see anywhere to "add" a new topic? I've done a wright up on lux diffs into a zook, and a G16A into a sierra, was going to put them in there to!
F&R ARB air lockers, lux diffs, 4 link coil rear,
Vehicle: 75 Cruiser
Post Posted: Mon Sep 28, 2009 10:30 am
see "Submit News" in your left menu...
or this link...
http://www.auszookers.com/index.php?name=News&file=submit
Post Posted: Mon Sep 28, 2009 11:34 am
thanks matey :)
Post Posted: Tue Sep 29, 2009 1:44 am
I started pulling out the tank in my sierra last night, to put an electric pump in for a g13b conversion, it sure is tight above the tank! Hardly any room to move! No lift on mine, and also a towbar which means I cant just drop the tank. Good to see I did it the same way as you, cheers :)
Vehicle: 1995 Sierra 1.3
Post Posted: Tue Sep 29, 2009 10:52 pm
Your tank looks a bit bloated now! 8O
Sierra 45L fuel tank mod!
Post Posted: Wed Sep 30, 2009 11:49 am
I'm going to drive around with 20 litres in a fuel container until it runs out. Then I'll put the 20 litres in, get to the nearest servo and fill the rest to find out how much it now holds.
Users browsing this forum: No registered users and 49 guests
