It is currently Tue Oct 20, 2026 1:18 pm
Vehicle: Sierra g16 efi..and Sierra GTi
Post Posted: Tue Feb 06, 2018 1:13 pm
I know it is the V6 VL commodore engine mounts that get used in a Swift GTi engine conversion... Is it auto or manual VL mounts.. Part numbers would be excellent if someone has them.. We have got everything I think except new mounts... Cheers..
Post Posted: Tue Feb 06, 2018 1:46 pm
Rb30e mount 3ltr straight 6
Should all be the same
Post Posted: Tue Feb 06, 2018 4:33 pm
Bursons recon the man and auto are different.. Thanks for the part number...Gives me somewhere to start..
Post Posted: Tue Feb 06, 2018 7:22 pm
I used ones that looked like this Kelpro mount. Had to grind the small tab off to fit.
Vehicle: 1992 suzuki sierra hardtop
Post Posted: Wed Feb 07, 2018 3:44 pm
I just use the normal 1.3 mounts
Post Posted: Wed Feb 07, 2018 4:22 pm
Most aftermarket standard ones are pretty weak. When you swap to higher hp efi motors the passenger side mount busts all the time as thats the way the engine torques. Ive had success using the repco ones but all the other ones would bust quickly. The vl mounts are good but can be a tight squeeze to fit on your own, an extra set of hands makes it a bit easier
Post Posted: Wed Feb 07, 2018 11:20 pm
Yes normal engine 48hp... gti is 101hp... so breaking mounts is common..
Post Posted: Thu Feb 08, 2018 4:45 am
Iv never broken one yet after about 5 engine swaps
Post Posted: Thu Feb 08, 2018 6:18 am
Guess it depends on your driving style
Vehicle: G16b sierra
Post Posted: Thu Feb 08, 2018 1:20 pm
ie skids or no skids
Post Posted: Thu Feb 08, 2018 2:05 pm
Yeah if ya gunna flog it a 7000rpm
Post Posted: Thu Feb 08, 2018 2:41 pm
The car needs new mounts anyway so why not put in stronger ones if they are around the same price ??? $58 delivered..
Post Posted: Mon Feb 12, 2018 10:52 am
This! If they don't bust (where the rubber-metal vulcanizing bond fails as opposed to the rubber tearing in genuine Japanese mounts) under moderate stress they end up sagging heaps! Same goes for aftermarket transfer case mounts
Lil Foot!
Users browsing this forum: Google [Bot] and 189 guests
