It is currently Fri Jul 24, 2026 5:12 pm
Post Posted: Sat Jul 07, 2018 3:49 pm
In the process of fitting a rear sierra 4 pin centre to my steel GV front housing with an auto locker.
The last piece of the puzzle is that the GV crownwheel doesn't hold the cross pins captive (see photo) and being able to slide about the will eat the pinion gear for lunch....
besides cable ties, duct tape and superglue... has anyone got some simple(cheap) ideas for us?
Post Posted: Sat Jul 07, 2018 3:57 pm
Heat shrink or MTB tube
Post Posted: Sat Jul 07, 2018 8:13 pm
Take the bearing end cap off and drill and tap a hole from that face down to the pin and put a grub screw in it. Also dimple the cross pin shafts so the grub screw bites into it but doesn't burr it.
Post Posted: Sat Jul 07, 2018 9:24 pm
Yep. I wouldn’t be trusting heatshrink or rubber.
Post Posted: Sat Jul 07, 2018 9:48 pm
I believe this is what this product from trail tough is for as another option.
https://www.trailtough.com/product/carr ... ning-cans/
Post Posted: Sat Jul 07, 2018 10:20 pm
Yass!
Post Posted: Sun Jul 08, 2018 10:02 am
Awesome thanks.
Armsup
Post Posted: Thu Jul 19, 2018 12:07 am
Start using american terms of tracker and samurai and you end up with more results.
Easy write up with pictures for those searching later.
http://www.zukikrawlers.com/showpost.ph ... stcount=29
Other options - with postage and current exchange close to $100 landed. Will suss getting a couple made, be borderline not worth the hassle though.
My 5.12 crown wheel's and Sierra centres showed up today. So I have spares I can experiment with.
http://www.zuksoffroad.com/RP-Retainer- ... p_291.html
http://www.petroworks.com/ring-and-pini ... ation-kit/
Users browsing this forum: Jezzer and 427 guests
