It is currently Sun Oct 18, 2026 10:32 pm
Vehicle: Suzuki Vitara H25A 1999
Post Posted: Fri Apr 12, 2019 9:24 am
Hi guys
Looking to do a SAS conversion on 1999 H25A auto 5 door Vitara
Cant seem to find much info on the 99/2005 shape they have rack and pinon steering and also abs so wheel speed sensors other than that appear much the same as the previous shape.I
s it better to stick with the ifs and mod it??
Was thinking of doing a yota KZ or LJ front axle and extending the rear 4 link keeping vit diff on 4inch lift to run 32s
Im from NZ and would like to get it cert ed so road legal if poss.
Be great to get some experienced feedback!!
Post Posted: Sat Apr 13, 2019 8:29 pm
SAS into IFS cars has been done - but not to a GV that I've heard of.
Probably some one in the US of A has done it, considering the sort of stuff they seem to be able to get away with.
NZ follows a fair bit of ADR stuff AFAIK - That would be a hard conversion to keep legal in Vic, but with enough perseverance, money & the right engineer, it should be in theory possible.
Best to talk to an engineer in your area - you would likely be pioneering it.
32" have been run on GV's over here - not legally though, 32" is just too much of an increase over stock - usually with a body lift & guard trimming.
Front diff & CV strength is a hard issue to overcome though, making a SAS seem attractive - maybe Hilux?
A 1999 would be rare in Aust. to have ABS sensors (unless a 'Limited' spec pack) - does your cars actually have ABS?
Yes, you would have to ditch the rack & pinion & go back to a box, probably from the same car as the axle would be best.
Good luck!
Rgs, Michael
Post Posted: Sat Apr 13, 2019 9:39 pm
It's been done by a guy in one of the caribbean islands (Trinidad) - unfortunately he's never shared the details, it's also been done in the US, I think you can find details on Pirate4x4 - I have my doubts about the possibility of having it certified/engineered, but I know nothing of the requirements in your corner of the world.
Post Posted: Mon Apr 15, 2019 8:25 am
All the builds ive seen cut the front frame off and tube it
Vehicle: Vitara 1994
Post Posted: Mon Apr 15, 2019 1:05 pm
To the OP why do you want SAS?
Post Posted: Fri Nov 08, 2019 8:33 pm
Build is progressing well not as hard as I thought it would be
Front end is complete just triangulating the rear.
I may set up a kit as a 1.5 tonne car on 35s with 12 inch travel in the front and 14 in the rear should be super competitive off road.
Actually fairly cheap to build using common parts!
Post Posted: Sat Nov 09, 2019 9:26 am
Pics!!
Post Posted: Sat Nov 09, 2019 12:44 pm
Yep will do once the rear is complete.
Is it easy to load pics on this forum??
Post Posted: Sat Nov 09, 2019 6:09 pm
I use imgur to upload to them share here. It's free
Post Posted: Sat Nov 30, 2019 6:39 pm
Front end just needs brake lines and Driveshaft and its ready to rip.
Post Posted: Sat Nov 30, 2019 9:10 pm
More pics!
Post Posted: Sun Dec 01, 2019 2:07 pm
I will load more pics last one was a bit of a mission to load so will try a different way later in the week
Post Posted: Sun Dec 01, 2019 8:04 pm
Use that imgur site!
Post Posted: Mon Dec 02, 2019 5:25 am
Few more pics!
Post Posted: Fri Jul 10, 2020 5:44 am
This build is now for sale if anyone is interested, time for the next project.
https://www.trademe.co.nz/Browse/Listin ... 2687056056
Users browsing this forum: Google [Bot] and 234 guests
