It is currently Mon Oct 19, 2026 11:41 pm
Vehicle: Suzuki GV Navigator 2015 SWB
Post Posted: Tue Nov 05, 2019 10:12 am
Hello,
First time posting. I am a total noob but I am looking to make my recently bought Suzuki GV Navigator 2015 SWB more off-road capable.
I am looking at adding a lift kit and some under car protection (and any other thing you might recommend).
I can find a lot of references to lift kits to previous year Suzuki GV models, but not to post 2015 models. And most of the online websites seem to just refer to the models up to 2015. Is this new model not really modifiable?
I would appreciate any recommendation that you guys might have.
Thanks a lot
Sergio
Vehicle: JT SWB Grand Vitara
Post Posted: Tue Nov 05, 2019 8:24 pm
Hi Sergio, my daughter has just done exactly the same - second hand late model SWB Navigator. I understand the JT 2005 to 2018 third series are all the same and production ended ~2018
I've bought a bash plate but need to fabricate an extension to protect the transfer box. I'm also trying to work out what I can do to protect the rear diff and muffler and maybe install a smaller muffler as it looks vulnerable. One of the guys on this site (Slug) has moved the muffler forward to beside the gearbox, still investigating that one.
I'm planning to lift it a bit however, seems there is a lot of negatives on this site re raised late model GV's chewing out front suspension bushes. Dobinson, Ironman and others do 40mm lift kits. ARB/Old Man Emu only do 20mm which isn't lift much for the money but maybe it's safer - ie more reliable.
Larger diameter tyres are also on the list, so tossing up how much bigger as I don't want to cruel fuel consumption. Maybe just go up from 70 to 75 profiles(?)
We aren't trying to get anywhere extreme or fast, just want to reliably get to nice spots for camping/kayaking/photography, and still have a reliable daily driver.
I'm also a Noob so hopefully some of the experts chime in and help us out!
Post Posted: Wed Nov 06, 2019 6:41 am
NGV’s use a suspension bush design shared with most FWD cars- in the front the rearmost lower wishbone bush is rotated 90 degrees so the bolt runs vertical. This means ANY suspension lift forces the bush into bind. OME have decided the maximum safe limit is 20mm, others have decided it’s 40mm.
Regardless, the big trade off is that any suspension lift on the NGV significantly reduces wheel travel. (We’ve proven this on a travel ramp comparing stock and lifted cars)
Under body protection is very wise.
Post Posted: Wed Nov 06, 2019 4:39 pm
Thanks Gwagensteve. I found that offending vertical bush. Sod of an idea!
Do you have a feel for how much tyre diameter increase can be tolerated before fuel economy and power suffers?
Post Posted: Wed Nov 06, 2019 8:13 pm
Thanks a lot for that kendb and Gwagensteve.
I'll follow your advice and just start with larger diameter (and better off road) tyres and some underbody protection.
Vehicle: 2010 3.2L V6 Grand Vitara
Post Posted: Thu Nov 07, 2019 1:26 pm
Dobinson or Ironman for your lift (OME isn't much of a lift and is hardly worth doing), and Ironman for your underbody protection (but it's not foolproof, I've welded extra bracing on my transfer case plate and have to take it off and bend it back into shape every time it gets hit).
Post Posted: Thu Nov 07, 2019 8:50 pm
Hi Ilama_au, have you lifted your gv and if so how much, how long has it been lifted, and have you had any suspension problems?
Post Posted: Fri Nov 08, 2019 2:20 am
What OME is offering is not a lift perse, but an uprated spring that reduces the "droop" when the vehicle is loaded.
Post Posted: Fri Nov 08, 2019 2:08 pm
I have. Mine's got an Ironman lift. It didn't go up much in the front (25mm before the bullbar went on), but 45mm in the rear (assuming the stock suspension sagged a lot as it would have been towing with the previous owner). I run the constant load springs front and rear.
They are firm, and the front shocks have a slight knock (at 30,000kms old), but I think I'll replace them with Dobinsons next to get a bit more height. They dramatically improved the handling.
Vehicle: Vitara Navigator
Post Posted: Tue Nov 12, 2019 12:22 am
Running a Dobinson 40mm lift and 245/70R17 KO2's
IMG tag won't work for some reason, so link for pic; https://bit.ly/2NYB2Ad
Post Posted: Tue Nov 12, 2019 11:58 am
Be aware - the more lift you have, the shorter the life of the front control arm rear bushes - this is a known weak spot on these vehicles.
Post Posted: Tue Nov 12, 2019 5:30 pm
They were flogged out before I lifted it. I replaced them with Superpro bushes (which have the added benefit of correcting caster on the passenger side): https://www.superpro.com.au/find/superp ... n-SPF3385K
Post Posted: Tue Nov 12, 2019 10:05 pm
If IIama_au is who I think it is, then that car gets used as hard as I have seen any NGV get used.
It's (or a car very, very similar to it :? ) holding up well.
Those Superpro bushes are the go - just got to wash them out & re-lubricate often if in dusty / dirty conditions.
I'm conflicted with these things, being IFS / IRS means that suspension lift gives much needed clearance - but at the expense of travel.
Go too high though & the ride becomes 'crashy' as it runs out of droop / down travel even over speed bumps.
I would love a NGV 3.2litre - & they (along with most of the 2010 on cars) have fairly decent traction control.
So, if an early car with no traction control, keep it low & rely on what there is of wheel travel to keep you moving along.
Late car with TC, go higher - 40mm is fine, but be prepared to be lifting wheels more often - which the TC makes a reasonable job of maintaining progress despite air under the tyre/s.
In either case, the 245/70R17 size is the best / biggest tyre to go for. The 3.2 has absolutely no problems in powering that size, the 2.4 copes ok, but does get blunted & fuel use would be higher.
But, the 3.2litre & some late cars came out with 18" wheels, which I don't know of a useful tyre available - need to find a set of 17". Early cars came with 16", in which case 245/75R16 is the biggest. Don't try that with the 2.0litre - even the 2.7V6 would struggle - drop to 225/75R16 instead. 3.2 will just take a 16" wheel (maybe not the stock GV rims though?) - very tight over the front brakes.
Suspension height is not the limiting factor in tyre size - that's the fault of the front strut spring cup.
The Ironman bash plate kit is a decent start point & ok for sand, snow & sloppy mud, but rocks & roots won't be friends. As there is no chassis to mount stuff on, it is a fine line between making the bash plates solid enough not to suffer damage & making them too strong, so that they are fine, but then transmit damaging force into the floorpan.
Rgs, Michael
Post Posted: Wed Nov 13, 2019 12:10 am
I am aware of the Superpro bushes, and whilst I haven't used them personally, my previous experience with polyurethane suggests the design is flawed, they slide rather than flex (poly is not the greatest of materials if flex is what you're looking for), and ZUZUKI has already outlined the challenges with them - they are exposed to grit & grime that gets stuck to the grease, and will cause premature wear - on a daily driven vehicle, disassembling, cleaning & relubing poly gets old really quickly.
Post Posted: Wed Nov 13, 2019 5:30 pm
Rgs, Michael
Hey Michael, yes, I am who you think I am 8) I have seen you mention my car a couple of times on here. I agree with most of what you've recommended except for tyre size. 245/70/16 is the most common size people chuck on them (if it's got 17s or 18s ditch them for 16s). Stock GV 16s (alloys or steels) fit all models, I went a set of '03 Hyundai Santa Fe alloys (16x6.5" +46 so what the GV runs on stock 16s) as they were crazy cheap and they were going to get scratched up and dinged anyway. Alloys are lighter. Though if I had my time again I'd go back to a 225/75/16. The extra width is honestly not necessary, you just want the height. 245/75/16 scrubs, avoid.
fordem - I've had SuperPro bushes in for approx. 2.5 years and ~33,000kms. They've been lubed once in that time. I've had no problems with them. They're certainly more durable in a lifted GV than the rubber bushes, therefore I have no hesitations recommending them. As Michael mentioned, I probably push this model GV harder than most in the country, so if they were going to fail they would have.
Cheers,
Juliette
Post Posted: Sun Dec 01, 2019 11:19 am
Hi Cur3n4, FYI with some trepidation we added a 40mm Ironman lift kit to the car and the following are our observations after a weekend in Sundown National Park. (if you don't know it, lots of loose granite gibbers and quite steep at times)
The ride does get firmer and the handling improves as there is less body roll due to the firmer springs. Apart from 30L of water, we load lightly as we are used to kayak camping. No bar work at all apart from the bash plate so the car was light - dropped ~10mm loaded. Still on road tyres.
Gwagensteve is quite right in that the suspension travel is effectively reduced as the springs don't compress as much, particularly when lightly loaded. So we spent a fair bit of time with one or two wheels in the air. May be a problem in the ultimate situation, but for our purpose, the traction control handled it so well, you would hardly notice.
If your gaol is as ours, to get to nice camping, kayaking and photo spots without damaging the car and not in a rush or trying to be a hero, then the trade off is great as the increased ground clearance gives much of peace of mind. We hardly touched the bash plate.
Users browsing this forum: No registered users and 250 guests
