It is currently Sun Oct 18, 2026 11:56 pm
Vehicle: Holden Barina
Post Posted: Mon Jan 13, 2020 1:27 pm
Hi there Suzuki lovers. I wonder if anyone could possibly tell be where the PCV valve is on a G13 BA engine, and how to extract it. I suspect it is on the block. It certainly
isn't on the rocker cover.
I have a 1993 Holden Barina 5 door 1.3 manual ( re-badged Swift). Many Thanks Eric
Post Posted: Mon Jan 13, 2020 3:22 pm
its in the top of the intake manifold right next to the rocker cover. It’s the thing that sticks upward with a T piece and hoses running to the rocker cover and airbox
Pretty sure it’s threaded so should screw out
And welcome to AZ!!
Edit: sorry I’ve just reread your post and yours is a Barina, I was thinking Sierra. I’ll try find out
Post Posted: Mon Jan 13, 2020 3:31 pm
Not sure sorry. It should look like this anyhow
Post Posted: Mon Jan 13, 2020 10:26 pm
This is the part number called out for the 93 Swift SOHC engine and it should be exactly where bumstein said it would be - find the hose from the rocker cover to the air filter housing, follow the tee to the intake - as far as I recall it doesn't screw in, but is held down be a plate with two screws
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 441 guests
