It is currently Sun Oct 18, 2026 10:31 pm
Vehicle: R50 pathfinder
Post Posted: Tue Jun 02, 2020 10:52 am
Gday, ive just put a 4k toyota carby on my sierra, new choke works, the accelerator cable seems to be fine, but when I turn the car on it just starts reving really high going nuts. Is there something I have missed? It didnt do it on the stock carby. Cheers
Post Posted: Tue Jun 02, 2020 11:06 pm
Is the 4K Toyota carb a double barrel downdraft? Are both throttle plates closed when they should be? Is the idle speed screw set correctly?
Post Posted: Wed Jun 03, 2020 12:28 pm
Yea no idea to all haha
Post Posted: Wed Jun 03, 2020 8:00 pm
With all due respect, if you can't answer any of those questions, you're in over your head and need to find someone with some amount of experience to assist.
Post Posted: Wed Jun 03, 2020 10:36 pm
Correct.. but for a start perhaps post some pics of your carby and setup and maybe we can help for starters? No guarantees!!
For starters make sure your start it up with the throttle cable and choke disconnected. It’s simple to hook the cables up just a little tight and not realise. I’ve done it before
Vehicle: Coily.
Post Posted: Thu Jun 04, 2020 9:23 am
Good advice,start there and work back.
Regards All from far Northern NSW.
Vehicle: Holden Drover '85 NT 1,3
Post Posted: Wed Jul 08, 2020 10:15 pm
you need a good stiff return spring to properly tension the factory throttle cable pivot point onto the 4K carby. I bought a collection of them from Bunnings and tried different weight springs till I got a good balance of return to idle vs too much weight needed on the accelerator. From memory the return spring just looped around the throttle cable end and hooked into one of the nearby hose clamps on the airfilter. About a $3 fix...
Users browsing this forum: Google [Bot] and 248 guests
