Vehicle: 1987 Suzuki Sierra
Posted: Sat Jun 20, 2020 6:31 pm
Gday lads and chicks Got a 87 tin top I am doing up for the road, mainly gonna be a shooting rig. So I went for a roady and got knocked back for the aggressive lean to the drivers side, I put brand new springs in to try fix the issue and I had no luck, they won’t pass it on the roady until it’s sorted so I’m stuck for what it could be, yes I know they lean a little bit but shouldn’t be leaning this bad. Any help is appreciated.
Did you put the correct springs on the correct side? It's not unusual for driver side & passenger side springs to be different and the longer spring is usually fitted on the driver's side - you also need to look for possible frame, axle or other suspension related problems.
Users browsing this forum: Google [Bot] and 248 guests
