It is currently Sun Oct 18, 2026 7:42 pm
Post Posted: Sat Oct 31, 2020 3:17 pm
Ive been given a bare gti engine with no wiring/manifolds ect...
Just curious if i can pop a sierra head on there as my lwb engine has done 315,000kms now and i figure it might pay to have a backup ready.
I know the gti has 4 valve notches out of the pistons to account for the 16v head.
My question is will the 8v sierra head valves line up on the gti piston crown ok ?
If they dont has anyone used a die grinder or the like to take some meat out of the gti piston to make it work ?
Post Posted: Sat Oct 31, 2020 6:20 pm
What about a BB jimny head? They're already 16v and you can buy them brand new (ask me how I know lol)
Post Posted: Sat Oct 31, 2020 7:27 pm
BB head is same as baleno
Perhaps if i could find a dead jimny bb motor
Pretty happy with the 4k carb setup wasnt really planning on going injection
Post Posted: Sun Nov 01, 2020 7:12 am
I'd say sell the GTi long block to a ricer and use the funds to buy a G16 or something that will work.
It sounds like the end result will be an interference motor with unknown compression ratio. alternatively, put carbs on the GTi.
Post Posted: Sun Nov 01, 2020 10:22 am
Might just rebuild it with some new pistons and see if i can work around the different gudgeon pin setup to sierras
Post Posted: Sun Nov 01, 2020 10:58 am
Rather than mess around with the pins, you should be able to swap the rods.
When I did the 8v engine in my Swift, I swapped the crank out for a GTI crank, just because it was available and forged.
Post Posted: Sun Nov 01, 2020 5:06 pm
Will the bike carbs work on a mk2 motor without ecu ect...
Dizzy should take care of the spark on its own ???
Vehicle: Vitara 1994
Post Posted: Mon Nov 02, 2020 10:46 am
I am with this.
You will not need the benifits that a gti block and head provide so sell on to someone who does
Sent from my SM-N960N using Tapatalk
Post Posted: Mon Nov 02, 2020 7:58 pm
If I recall correctly, no, it's not a self contained ignition system, timing advance is handled by the ECU - the distributor just handles the cam sensor and distributes the spark.
Users browsing this forum: Google [Bot] and 234 guests
