It is currently Mon Oct 19, 2026 5:46 pm
Vehicle: Suzuki sierras
Post Posted: Sun Nov 08, 2020 1:04 pm
G'day just wondering if you people would be happy with this pattern? it is in a Suzuki sierra rear diff with an arb air locker if it makes any difference.
cheers Jack jr
Post Posted: Sun Nov 08, 2020 2:13 pm
No. Should be centred on the tooth.
Post Posted: Sun Nov 08, 2020 2:51 pm
ok thanks do i need to shim the pinion towards the ring gear or away?
cheers Jack jr
Post Posted: Sun Nov 08, 2020 4:14 pm
Did you do a gear change or just the locker? If it’s just the locker there’s no need to touch the pinion.
Post Posted: Sun Nov 08, 2020 5:09 pm
I had a locker fitted by arb last year I only pulled it apart to rebuild it as the pinion seal was leaking and there was a small amount of play in the pinion shaft.
it has the original shim in it when i checked that pattern. how to i centre it more on the tooth? thanks for your help.
cheers Jack jr.
Post Posted: Sun Nov 08, 2020 5:13 pm
Have you got a solid pinion spacer Jack?
Post Posted: Sun Nov 08, 2020 5:47 pm
no its a crush sleeve I have been using the old one to test the pattern.
Post Posted: Mon Nov 09, 2020 6:04 pm
Does anyone know how to centre the pattern? it is the original gears and the original shim the back lash is set at 6 thou at the moment.
Cheers Jack jr.
Post Posted: Mon Nov 09, 2020 7:45 pm
Sorry jack, my FSM isn’t with me now.
Post Posted: Mon Nov 09, 2020 8:33 pm
no worrys.
Post Posted: Thu Nov 12, 2020 6:04 am
I have done some research and it seams that if the pattern is down on the toe on the drive and coast side, then I need to increase backlash. How much backlash can you run in a sierra diff?
Cheers Jack jr.
Post Posted: Thu Nov 12, 2020 6:49 am
This I know. 0.13-0.18mm
Post Posted: Sun Nov 15, 2020 8:21 pm
G'day i tried to put the diff together tonight but i found that the new pinion spacer is shorter then the old one by about 0.1mm, I fitted it but the bearings went tight before the crush sleeve started crushing.
why would this be where there different ones of is the a defect? i ordered the kit from 4wd products on ebay.
Cheers Jack jr
Post Posted: Mon Nov 16, 2020 7:16 am
If I put a shim under the crush sleeve to build up the Hight would that work? How tall is a crush sleeve when new my new one was if I remember correctly 55.4mm tall.
Cheers Jack jr
Post Posted: Thu Nov 19, 2020 8:32 am
Sounds like your in way over your head
Perhaps have a fiddle with a cheap center before you attempt the locker
Post Posted: Sat Nov 21, 2020 9:35 am
G'day, you are probably right MrRocky but i spoke to a few people and get it as good as i could,
I put it back in last night and it is not whirring it gets warm after a short drive but i would say that is fine?
just have to see what happens over the next few km.
Cheers Jack jr
Post Posted: Sat Nov 21, 2020 11:42 am
after a short road run of 15-20km with a stop in the middle the diff centre would be guessing about
50C I put the upper limit of preload would you consider that ok?
Cheers Jack jr
Post Posted: Sat Nov 21, 2020 9:10 pm
I normally ugguh duggah it until sits where it was on the thread previously or just a tad more.
Setting the backlash correctly can be tricky, i normally try and match the front diff as generally its pretty fresh by comparison to the rear.
Users browsing this forum: Google [Bot] and 226 guests
