It is currently Thu Jul 30, 2026 12:08 am
Post Posted: Thu Jul 01, 2021 8:38 pm
Are there any main differences between the diffs sj40/sj50 apart from ratios, have just picked up a couple of Zuke”s and side by side comparison they look interchangeable, being a narrow rack or am i dreaming
Sik as drover, 32" mongrels, 4age 20v, 2" sus, 2"
Post Posted: Fri Jul 02, 2021 7:52 am
You’ll need to clarify what you mean by “diff”
The completed axle assemblies will interchange with the appropriate yoke fitted to the driveshaft and some messing with u bolts and spring plates.
The front and rear axleshafts will interchange.
Front knuckles will interchange along with front brakes assuming it’s a disc brake SJ40.
The housings, diff centre and ring and pinion gears are unique between each model and do not interchange. Sj40 is considerably smaller.
Users browsing this forum: Google [Bot] and 586 guests
