It is currently Fri Jul 24, 2026 12:51 am
Vehicle: 2004 Jimny Manual
Post Posted: Tue Jan 25, 2022 2:41 pm
Hey guys picked up a 2004 jimny with a 1.6 block and 1.3 head, I got a compression test just incase but wondering if these numbers are normal, thanks
Post Posted: Tue Jan 25, 2022 7:43 pm
500kpa is only 72psi.
I would expect the compression to be 180psi or thereabouts. Is there something I'm missing?
Post Posted: Wed Jan 26, 2022 9:38 am
Yeah, I was sitting on the couch last night and ended up putting that figure into a converter because working it out in my head was giving me a ridiculously low number....like 72psi.
250KPa is 36.7psi. I have no idea where your mechanic gets that figure. For a stock G16B, minimum compression is 1200KPa, standard is 1400KPa.
Did he miss the 1 off the start of off of all those figures?
Post Posted: Wed Jan 26, 2022 2:10 pm
I’m hoping that’s the case , I’ll be asking tomorrow, it would make more sense if a 1 was missed from the start of all the numbers, it wasn’t the mechanic that wrote it , it was the lady at the desk. Just doesn’t seem right because it doesn’t blow any smoke, no leaks, starts easy, no strange noises, doesn’t chew oil and no loss of power.
Post Posted: Wed Jan 26, 2022 8:36 pm
Even if he did, the variation in between the cylinders is I believe out of spec.
Users browsing this forum: Google [Bot] and 524 guests
