It is currently Mon Apr 20, 2026 3:41 am
Vehicle: 1993 sj70 soft top
Post Posted: Tue Feb 08, 2022 2:14 pm
looking at buying this lift kit, wanted to see if anyone has experience with this particular kit, or with this spring and shock combination
https://www.onlineautoparts.com.au/prod ... /ZPN-02499
Post Posted: Tue Feb 08, 2022 7:39 pm
EFS springs are very stiff, see this thread: viewtopic.php?f=5&t=57113
Post Posted: Wed Feb 09, 2022 7:11 am
would taking a leaf out of the pack help with getting more flex?
Post Posted: Wed Feb 09, 2022 11:58 am
Theoretically yes. If you read that thread though, you’ll note the EFS springs were derated (one leaf removed from the front, two from the rear) and it was still excessively stiff.
Post Posted: Wed Feb 09, 2022 12:37 pm
aside from ome springs, which were the comparison in the other thread, is there any others that you would recommend
Vehicle: 86 SJ413 31's 1.6
Post Posted: Wed Feb 09, 2022 4:29 pm
I got talked into getting EFS 8 years ago. I just got the springs and got some shocks separately. I don’t find them stiff but the ones in it before were worse. What I don’t like about them is the driver side sagged after 2 weeks of just sitting in the garage, complained got two new ones and it did the same.
Post Posted: Wed Feb 09, 2022 9:28 pm
I have springs in the rear of Sierra which are identical to EFS just a different branding. EFS springs are imported so there's a couple of different brands on the same spring. I have the top 3 leafs from my set with the bottom leaf from an LJ80 set. It rides well, takes a load well, can reach the bumpstops when flexed and is probably 30mm taller than stock originally was. My front is RUF with stock rears.
I have a set of those ultima shocks. The fronts are longer than they say, about 320 long compressed instead of 300 (to the base of the pin). They will need some bumpstop spacing. I think the rears were fine but shit, that was like 3 or 4 years ago when I fitted them so memory could be wrong.
Post Posted: Thu Feb 10, 2022 12:12 pm
seems like that kit is fairly rubbish, what shock and spring combination should I be going with? I have a budget of $1000, and want a setup that flexes well, in rocks and ruts. I am currently running 29s on saggy factory springs and tired bushes, so anything is improvement
Post Posted: Fri Feb 11, 2022 6:42 am
Old man emu from ARB. I haven't bought them for many years but they were around $450 for a set of springs, shocks should be a similar amount and then you'll need bushes and u bolts. It will flex okay in the rocks and ruts, about as good as can be expected from an off the shelf kit. Remove the front sway bar if you haven't already.
Post Posted: Fri Feb 11, 2022 10:46 am
cant find prices for ome anywhere online, will i have to contact arb?
Post Posted: Fri Feb 11, 2022 12:08 pm
Yup.
Post Posted: Fri Feb 11, 2022 5:31 pm
If you google ARB price list and chose the latest one. But it doesn’t have the price for the springs
Vehicle: 1991 Sierra WT SJ413
Post Posted: Wed Feb 16, 2022 6:32 pm
ARB prices are $147 for front spring and $159 for rear. Price per spring ex GST.
