It is currently Fri Jul 24, 2026 6:20 pm
Vehicle: 1999 Jimny
Post Posted: Mon Oct 05, 2009 10:59 am
Is the G16a block the same as the G16b block????? don't give a hsit about pisstins just need to know about putting the fuel injectioon head on an "a" block.
Post Posted: Mon Oct 05, 2009 11:24 am
AFAIK, with regards to the important stuff like oil galleries and water jackets lining up, all the G series blocks are compatible.
There are the obvious differences such as the transmission mount difference between 613 and G16 (which is why we need to us an adapter kit with the Sierra 5 speed), and the driver's side engine mount. I have seen a couple of G13 blocks with different mounting points for power steer, but I think this might be something like a Sierra vs. Swift thing.
One thing that is different between early and late models of g16 is that some earlier ones had a closed deck. Most G series blocks I have seen, when you look at the top of the block around the bores this is completely open, like this (pic of Honda engine btw)...
...whereas on some earlier G16s it looked like this
I have a few heads and blocks at home if you want to check anything specific.
Vehicle: 1999 Jimny
Post Posted: Mon Oct 05, 2009 10:43 pm
So there should be no problems in putting a Fool injected head on a G16A???
Vehicle: SJ80
Post Posted: Mon Oct 05, 2009 11:18 pm
G'day mate, here's some photo's of the 1.6 in my coily. On the back of the block is cast "G16A". As you can see it has a fuel injected head.
Vehicle: 1999 Jimny
Post Posted: Tue Oct 06, 2009 12:40 am
Cool Beans!!!!!!!!!
Post Posted: Tue Oct 06, 2009 2:20 am
Works fine. Thats exactly what I did 8)
Member of C.O.R 4x4
Users browsing this forum: No registered users and 313 guests
