[ 6 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
cvau
Vehicle: Suzuki Sierra
 Posted: Sun Jan 14, 2024 11:13 am |
Hi All,
Is it possible to install AC to an old 85' Drover, I read somewhere that they had it as an aftermarket option? And if so, where should I start?
I bought a Drover and the hot/cool air doesn't blow, so I need to investigate this. It got me thinking if I should consider AC at the same time, depending on what's required.
Thanks in advance!
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13013 Location: Melbourne
 Posted: Mon Jan 15, 2024 4:52 pm |
Yes, A/C was an option.
Complete kits removed from cars turn up from time to time for sale. It's a fairly complex collection of parts to source and install though - there's a wiring harness, double row crank pulley, the A/C switch added to the heater panel and I believe a pusher thermo fan to assist.
When you say "doesn't blow" does the fan not run or is there no air flow despite the fan running?
cvau
 Posted: Mon Jan 15, 2024 6:53 pm |
Fan not running, no activity whatsoever from the controls. I have the FSM now and I'm planning to do some troubleshooting, fingers crossed that it's something simple.
Sounds like the A/C should be a job for another day, or maybe not at all?
Gwagensteve
 Posted: Wed Jan 17, 2024 8:18 am |
There’s three different things going on here. Blower fan is obviously electrical, so fuse, then switch, then resistor pack, then motor.
The air direction controls move air doors on heater box itself. This is a 100% mechanical process. The fresh/recirc snd floor vent levers and doors are visible with no disassembly.
The heater control is a tap on the firewall. Operated by a cable that passes through the firewalll.
If none of these levers is doing anything I’d suggest the heater box and or dashboard has been out and never put back properly/at all.
cvau
 Posted: Thu Jan 18, 2024 7:54 am |
Got it working but not sure exactly what I did, I think it was to do with the fan speed switch. Maybe it’s dirty contacts.
The other control cables seem to be functioning correctly, but the demist setting isn’t blowing.
Should I be able to see the physical switching between fresh/recirc to verify it’s working?
Thanks for the suggestions.
Gwagensteve
 Posted: Fri Jan 19, 2024 7:32 am |
Fresh/recirc is operated by a straight rod look under the glovebox to see the door. You’ll hear a “thwump” sound as the door shuts when switching to fresh.
[ 6 posts ] |
Users browsing this forum: Google [Bot] and 218 guests
