It is currently Tue Apr 28, 2026 4:40 am
Post Posted: Thu Oct 08, 2009 12:41 am
Hey i know this is backwards to what everyone else does but can a Vit 5speed manual be bolted up to the back of sierra G13A? I've heard of people just drilling holes to get the 1600 to bolt to a sierra box could it work but in reverse?
Just a build idea...
Post Posted: Thu Oct 08, 2009 12:46 am
Would work, but why? If your going to the trouble of the box, 1.6 at the same time. :roll:
Post Posted: Thu Oct 08, 2009 8:43 am
On my p's but want to run a vit TC...
Post Posted: Thu Oct 08, 2009 11:32 am
with sierra case as well yes?
Post Posted: Thu Oct 08, 2009 10:10 pm
hehe yes, will be running a crawlered vit case, 1L sierra case, lux 4.8, 35s, and a sierra box.. will run 100kms @3000-3500rpm 8) not sure if it's revy enough but will be looking for a efi 16v vit motor once on my blacks...
With a sierra gbox it will be pretty much spot on standard with 35s, but with a vit box i don't know how much different it will be... Do you have the specs as I'm trying to find out my gearing...
Post Posted: Fri Oct 09, 2009 12:04 pm
Vit transfer has 1:1 high range
Post Posted: Fri Oct 09, 2009 1:12 pm
cheers, I knew that already i was refering to the Gear Box
Post Posted: Fri Oct 09, 2009 10:56 pm
4 cyl Vit and Sierra have the same internals in the box (some gears are wider), so the ratios are the same, except for 5th which is swapable between the 2.
1st: 3.652
2nd: 1.947
3rd: 1.423
4th: 1.00
5th: Vit .845, Sierra .795
V6 Vits have the same gearbox as a Hilux G52 Box with slightly lower 1st gear, but the bellhousing doesn't mate to a G13A block as easily, and the 4cyl bellhousing doesn't mate up to the V6 box!
Post Posted: Sat Oct 10, 2009 8:55 pm
Hmm ok cheers :)
Post Posted: Sat Oct 10, 2009 9:48 pm
Put a V6 in it :roll: 8)
Post Posted: Sat Oct 10, 2009 11:18 pm
no
Users browsing this forum: No registered users and 77 guests
