It is currently Wed Nov 04, 2026 1:25 pm
Post new topic Reply to topic  [ 823 posts ]  Go to page Previous  1 ... 19, 20, 21, 22, 23, 24, 25 ... 28  Next
Post Posted: Thu Nov 15, 2012 12:42 pm
ball wrote:
ball wrote:
Oi woggy can I get 10 inch drums with parallel bearings?
yep,
landcruiser pattern
F100?
nope
we have been through this
That was yesterday, was hoping you might have come up with something.
Did you call the mob I suggested?
Vehicle: LJ20 LJ50
Post Posted: Thu Nov 15, 2012 5:37 pm
ball wrote:
yep,
landcruiser pattern
F100?
nope
Hopeless you are arnt you
http://www.trailersparesdirect.com.au/h ... hub-drums/
Part number HD10X2F100P 10" x 2.25" F100 Stud Parallel Bearing
Camels have nice toes
Post Posted: Mon Nov 19, 2012 1:25 pm
Thanks tzar. Well priced and good to deal with. Hopefully they will get here fast.
Vehicle: 2002 Suzuki XL7
Post Posted: Mon Nov 19, 2012 1:45 pm
Thought i would post this for people that dont know, Currently Sprint Auto is throwing out 10" Pneumatic jocky wheels for $32 each! got me self one and they look pretty good. Will be replacing the small 8" or even thinking about welding it on the other side so have the 8" as a back up or for extra stability once the camper is parked.
The 8" is impossible in sand. or any soft ground.
Post Posted: Mon Nov 19, 2012 1:51 pm
I have a 10" pneumatic on mine.
It obviously slows down the sicking in soft stuff,
but it is a pain for normal use,
very hard to get it to change direction.
I put the 6" dsolid back on today,
and will use the 10 "on trips.
Post Posted: Tue Nov 20, 2012 7:29 pm
word up lads,
ive got a the front cut of a chassis from a lwb vit, and ive had this idea of making a trailer out of it, using the front suspension off the half cut, springs, struts, welding on a draw bar, and locking up the steering.
Would it be a good base to build a trailer up from, or should i just give up on the idea and take the whole lot to sims with my swb.
Tell me why its a crap idea :wink:
Post Posted: Tue Nov 20, 2012 8:27 pm
Sounds like your looking for an excuse to scrap it! 8O
Post Posted: Tue Nov 20, 2012 8:33 pm
crap idea & you should do some work on the coona or i'll post those neglected pics of it in your build thread.
Post Posted: Tue Nov 20, 2012 8:46 pm
Ha, as you know ive got a lot of crap around here i need to get rid of, dunno if i should keep this for a longterm project :rofl:
It ticks a lot of boxes...same width, pcd, good size bearings, independant suspension.
Post Posted: Tue Nov 20, 2012 9:06 pm
Just put the calmini in the lwb and wheel it already, then you can throw away all the other shit you won't use! :lol:
Post Posted: Tue Nov 20, 2012 9:19 pm
haters gonna hate
this is a trailer thread, please keep on topic, or i'll have you banned :thefinger:
Post Posted: Tue Nov 20, 2012 9:25 pm
I seen a good trailer using a swift rear end
No more details, not seen it fer ages.
Why not leave the trailer wheels steerable :)
Post Posted: Wed Nov 21, 2012 6:42 am
If you want to build something different you'd certainly achieve it, but, I'd imagine that all that metal (chassis, arms and struts etc) would make for an unnecessarily heavy trailer.
Can't beat leaves and solid axle for durability, reliability etc etc.
But if you want to do it, just do it!
Post Posted: Wed Nov 21, 2012 7:18 am
I had a trailer on my Moke made from the rear of a Moke, it towed fantastic, and looked cool.
But it was heavier than a similar sized normal trailer.
Post Posted: Mon Dec 10, 2012 6:20 pm
Borrowed my father in law's boat trailer until he needs it again. Needs a small repair.
Post Posted: Tue Dec 11, 2012 5:25 pm
Fixed
Vehicle: 2011 jimny
Post Posted: Tue Dec 11, 2012 6:07 pm
like new Armsup
Post Posted: Tue Dec 11, 2012 6:45 pm
Was the trailer made out of gal rhs, and someone used a bit of painted rhs in that spot?
Post Posted: Tue Dec 11, 2012 7:34 pm
I think the trailer had never been gal dipped and must have been stored in a way that let water pool on the right hand side. That section has already been replaced in the past. The new section is gal plated so hopefully it will last for a while. I'm going to pour motor oil down both sides to hopefully help prolong its life.
I'll need to replace the mud guard mounting plates in the near future as they're looking a bit cancerous too.
Post Posted: Wed Dec 12, 2012 11:30 am
The small square section welded on the end doesn't pool the water, maybe add a couple of drain ones anyways.
Post Posted: Wed Dec 12, 2012 1:06 pm
Nah, square section has a 20mm gap under it. Drain holes may be a worthwhile addition. I had another look over the rest of the trailer and am pretty sure it actually was originally gal dipped.
Maybe during the gal process the area did not get good coverage, or maybe the mudguard supports were an add-on (they look it) which damaged the gal coating. Who knows, at least I have a trailer for the festive season.
I would still like to find my own at some point.
Vehicle: 2012 jimny
Post Posted: Wed Dec 12, 2012 8:11 pm
should build your own. just copy the father inlaws
Post Posted: Wed Dec 12, 2012 9:05 pm
It could happen
Post Posted: Fri Dec 28, 2012 2:05 pm
Finally motivated myself to finish off the overhaul on my borrowed boat trailer.
New LEDs, number plate remounted plus rego label.
Then decided to fab a mast support so I don't have to put it on the roof anymore.
I'm still on the hunt for my own trailer but the nature of their use means pickings are a bit scarce.
Post Posted: Sat Dec 29, 2012 2:22 pm
That looks good Nutter 8) it might be just the angle of the pic but that mast support looks really close to your spare wheel :? ya wouldn't want to take out ya nice airbrush work :(
Post Posted: Sun Dec 30, 2012 8:14 am
It's not the angle. For general towing it won't make contact though. Backing it into my backyard may be a different story though, I'll have to be careful.
Vehicle: Lwb vit, 31's big white fridge
Post Posted: Fri Jan 11, 2013 9:34 pm
All this trailer talk has got me sold on making my own trailer to tow behind my vitara. I'm very jealous of some of you. :peaceout:
Post Posted: Fri Jan 11, 2013 9:42 pm
Well we've already made all the mistakes for you, so yours will be perfect.
Post Posted: Fri Jan 25, 2013 10:46 am
Just a thought, what would these be like on a camper?
Would stop the tyres from hitting the arches when fully loaded.
I dont have shocks, nothing has been broken in my camper as yet, including loose packed eggs, my fridge doesnt even move from its spot on rough dirt roads, so are they really needed?
I have pretty big tyres on the camper and offroad leaf springs, apparently a solid axle too.
Post Posted: Fri Jan 25, 2013 10:56 am
Can't see why they wouldn't work on a trailer. Looks like a great product!
Users browsing this forum: No registered users and 7 guests
