It is currently Sun Sep 20, 2026 7:54 pm
Post new topic Reply to topic  [ 70 posts ]  Go to page Previous  1, 2, 3
Post Posted: Fri Apr 05, 2013 10:03 pm
Rusho wrote:
I'm assuming adding wet rags and the like will cool the housing to quickly, causing it to constrict prematurely. I think the norm is to let it cool 'naturally' for use of a better word.
Yep. Best to let the steel 'normalise', as slow as possible. This will reduce the internal stresses within the material.
For example, when you weld a diff centre, you wrap it in rags, then bury it in a bucket of sand so that it takes many hours to cool. ( or atleast thats how I do it :wink: )
Post Posted: Fri Apr 05, 2013 10:09 pm
a lot of weld procedures call for post heat as well as preheat. reduces hydrogen cracking.
Post Posted: Fri Apr 05, 2013 10:12 pm
This is also done on real big scale too.
At work they run a weld around the dozor wheel to 'pad' it back up again after it gets flattened/worn away by many hours of use. Then using hard facing wire subarc wire, they pick it up with a special crane, lifted over a bin and placed in it then sand is poured in ontop to keep the heat. Eventually it cools down, but takes ages.
One of the blokes reckons his seen a 1000mm Dia by 300mm wide cast wheel crack right in half because it wasn't put in sand.
Post Posted: Fri Apr 05, 2013 11:04 pm
Yeah cast is tricky. Fortunately I've had little to do with it.
Vehicle: 1985 lwb sierra UTE
Post Posted: Sat Apr 06, 2013 7:45 pm
I used to machine cast (durabar) its a strange material.
Post Posted: Thu Jul 04, 2013 8:32 am
to bump this back up. im looking to truss my front and rear diffs in a similar manner as below and as g-wags suggested. what sort of size material should i be looking at to make it strong enough.
note the diffs im looking at using are vitara rear housings.
Post Posted: Thu Jul 04, 2013 8:59 am
If you gusseted in the inside, I myself would use 3mm. Otherwise, 5-6mm.
Post Posted: Thu Jul 04, 2013 10:45 am
^X2
My Jimny front is 6mm cause the top link takes all the braking force, I didn't want it to twist the housing or to place the strain in just one spot.
My rear is 3mm
Post Posted: Thu Jul 04, 2013 6:57 pm
I'd say 3mm, but go for 350mpa just to bump up the strength a little. Its only a LJ, so 5-6mm would be complete overkill.
Post Posted: Fri Jul 05, 2013 8:23 am
what would you charge to do it pete? that way i know its done proper like
Users browsing this forum: Google [Bot] and 183 guests
