It is currently Tue Oct 13, 2026 1:51 pm
Post Posted: Mon Jun 27, 2011 7:13 am
long story short mates got a NT LWB Zook .. wants to make it into a Budget weekend weapon
info
Engine size 1.0
currently on 30 inch tyres
ideal spending 2k ish
My ideas
Put a set of WT axles onto it
and Tranfer Gearing .. maby 5.1
2 inch lift maby 2 inch body ..
Twin auto lockers
or maby just rear
anyone see anyproblems with this setup ? thanks ideas welcome :)
Post Posted: Mon Jun 27, 2011 7:14 am
What size tyres are you planning on running?
I want my old sig back :(
Post Posted: Mon Jun 27, 2011 7:16 am
TryHard wrote:
l
To low geared for std trye's....
2in sping lift, transfer gear's, twin locked & w/t = weapon!!!!!
Post Posted: Mon Jun 27, 2011 7:17 am
atm hes running 30 .. he might go 31s .. maby 33s .. not to sure
problems is im trying not to gear it to low .. maby forget the ring and pinion change and just go 5.1 transgears ?
Pretty low for even 31s, especially in high range...
Post Posted: Mon Jun 27, 2011 7:23 am
ok Just edited the first post does that sound better ?
Post Posted: Mon Jun 27, 2011 7:25 am
Its a 1L.
Post Posted: Mon Jun 27, 2011 7:28 am
Ah true...
Still would be a little on the low side with those diff gears I'd have thought...
Post Posted: Mon Jun 27, 2011 7:33 am
Ben_Sierra wrote:
Ah true...
Really? It has 4.1's now. And WT's are 3.7's so that makes it taller. Then you add the 5.1 transfer gears which are only 6% lower than the standard 1L case in Hi, and I'd say he need more gearing, not less.
For 30-31's and a 1L motor You should aim for 6.5 transfer, and if that not low enough get some 3.9 NT centres or 4.1 WT maruti centres. Otherwise the 5.1 transfer and some 4.6 vit r&p's would work also.
You MUST keep the 1L revvng.
Post Posted: Mon Jun 27, 2011 7:37 am
Ben_Sierra wrote:
Ah true...
I guess... I haven't crunched the numbers for a 1L so I could be way off the mark with my guesswork... Of course, I didn't initially notice it was a 1.0L...
Post Posted: Mon Jun 27, 2011 7:39 am
Yeah well if you think its bad to be undergeared in a 1.3, just image have 30% less power with those same gearing issues!
1L are a great thing offroad, but suffer from large tyres exponentially more than the 1.3 does.
Post Posted: Mon Jun 27, 2011 8:49 am
Ok so maby 6.5s ? then if its not low enuf run a different ring and pinion ?
Post Posted: Mon Jun 27, 2011 8:57 am
That will be the easiest/ cheapest way. 6.5's are great value for money.
Post Posted: Mon Jun 27, 2011 9:06 am
ya i run them in my sierra and love them .. :)
i was just worryed about gearing to low but i guess its a 1.L engine haha
so thats not posable to gear to low
Post Posted: Mon Jun 27, 2011 9:11 am
It is.....
The 1L has 12% lower Hi-range gears than a 1.3 sierra already, so the reduction is far less than it would have been for your 1.3L.
Post Posted: Mon Jun 27, 2011 9:13 am
It is.....
ah ok well thanks Fatzook :)
Users browsing this forum: Google [Bot] and 146 guests
