It is currently Sun Aug 02, 2026 8:10 pm
Poll: what do u think is better Calmini 6 inch lift combo or the tough dog 2 inch lift with a 2 inch body lift also
calmini 6 inch combo lift kit 60%  60%  [ 6 ]
tough dog 2 inch lift with a 2 inch body lift 40%  40%  [ 4 ]
Total votes : 10
Post Posted: Thu Oct 06, 2011 9:28 pm
hi l am stuck between the choice of the new tough dog suspension likft kit and a body lift kit which l have heard is great and also the calmini 6 inch combo lift kit, has anyone used either what do u all think works better, do u need a engineers certificate for either, this is all for a suzuki vitara 1990 jlx.
Post Posted: Thu Oct 06, 2011 9:46 pm
What do you wish to achieve with the lift?
Post Posted: Thu Oct 06, 2011 9:59 pm
more ground clearance and room for larger more aggressive tires, with more articluation
Post Posted: Thu Oct 06, 2011 10:00 pm
the calmini bodylift supplied in there 6" combo is just pure junk.
Post Posted: Thu Oct 06, 2011 10:04 pm
ok fair enough bt what about there three inch suspension lift kit with a body lift from else where.
Post Posted: Thu Oct 06, 2011 10:11 pm
What size tyres do you want to run?
Keep in mind the bigger you go the weaker everything gets so you have to factor a new front diff, lots of spare CV's, maybe rear axles, diff or transfer gears
Off the shelf the calmini lift is probably the best kit but nobody makes a great system, its all mix and match
Bodylifts dont seem to add much in teh way of clearance in a vit either so its worth considering other means to get clearance
Post Posted: Thu Oct 06, 2011 10:15 pm
l would like to run the maxxis bighorn 31x10.5
is there any parts that u can replace the factory ones with that are very reliable and near unbreakable.
1990 suzuki vitara stock with big plans
Post Posted: Thu Oct 06, 2011 11:29 pm
My Vit runs 31's with a 50mm body lift,
old man emu springs, and 50mm coil spacers,
and some shaping/bashing/cutting of guards.
Post Posted: Fri Oct 07, 2011 12:44 am
yeah l would much prefer to not have to damage the guards
Post Posted: Fri Oct 07, 2011 1:21 am
is it going into a LWB or a SWB & what type or terrain/4wding do you plan on doing?
the alloy front diff can be replaced with a couple of different options. eg. calmini anvil/GV 3rd memeber or a complete GV steel housing & steel 3rd member.
cv's are the weak point if abused.
Post Posted: Fri Oct 07, 2011 1:36 am
it is a swb
terrian is basically everything l go on the beach a bit, mud as much as possible and rocks and hill climbing occassionally
Vehicle: 2004 KJ jeep cherokee
Post Posted: Fri Oct 07, 2011 2:28 am
body lifts are illegal though, always have been...
If at first you don't suceed... lower your standar
Post Posted: Fri Oct 07, 2011 2:33 am
Is only the inner guards, nothing visible.
But you can limit up travel, with eg bump stop spacers,
to save cutting guards.
Post Posted: Fri Oct 07, 2011 2:45 am
Now there's bullshit right there. :roll:
They are legal if you get the paperwork, fit the bodylift and then take car to Main roads for inspection. :roll:
Post Posted: Fri Oct 07, 2011 2:47 am
X2 WTF......................... :crazy:
Lil Foot!
http://tiny.cc/gtsw1
Post Posted: Fri Oct 07, 2011 2:51 am
Only for vehicles with airbags.
Did the Vitara ever have airbags?
2002 SWB GV
Lifted and Locked
Post Posted: Fri Oct 07, 2011 2:55 am
i'm happy with my calmini kit in my vitara, although it does need some tweaking to get it to perform how it should. if you've got a spare couple of minutes have a look through my build up thread. :lol:
i'm running 31's with a 2" bodylift + 3" calmini super articulator kit modified with calmini GV front springs, OME front struts, bumpstop extensions, rear calmini 3" springs, commodore shocks + bumpstop extensions. the springs have settled nicely to about 2.5" with the weight of the 2.0L J20a, front bar, bash plates, rear drawer system & fuel tank guard brings the weight up to close to what calmini suggest it rides a lot nicer.
Post Posted: Fri Oct 07, 2011 11:19 am
Ok thanks so l wont get the calmini body lift but l might get the suspension although with new control arms it has to be engineered yes so l think l migjt go the tough dog kit with adjuable shocks
Post Posted: Fri Oct 07, 2011 6:28 pm
More Bs, it depends on the sensor's...
Post Posted: Sat Oct 08, 2011 3:50 am
they r illegal unless mod plated, should have stated that earlier sorry, I only say this from working with DOT queensland. I see many 4x4's getting defected by cops because towner have body lifted their rigs and not mod plated them and comming in and complaining...
dunno about airbags though...
Post Posted: Sat Oct 08, 2011 4:17 am
i run this but without the coil spacers, so yeah pretty low. have 1.5" bumpstop extension on the rear.
i voted calmini, but use the other BL. buy one from just cruizin on here. i didnt buy calmini because it was to expensive at the time, already had a 2" bl so would of been to tall with only 29s. i also dont have a steel bar/s or any additional weight.
Post Posted: Sat Oct 08, 2011 4:57 am
Get it right. :roll: :wink:
There is NO MOD plate (blue plate) for a body lift. You only get paperwork that you keep in your glovebox.
Post Posted: Sat Oct 08, 2011 11:00 am
Post Posted: Sat Oct 08, 2011 11:22 am
BIGCAMMY wrote:
I couldn't have said it any better :lol:
Post Posted: Sat Oct 08, 2011 1:25 pm
Lol l ment to say but obviously it didnt work l dont have any added wieght other then a bull bar which l may buid in the future
Users browsing this forum: No registered users and 284 guests
