It is currently Thu Oct 08, 2026 2:08 pm
Post Posted: Mon Oct 10, 2011 5:05 am
ok so i got sick of tightening up my alt belt over the last few months.. and the last time i did it i noticed the alt was on a bit of a angle.
so i decided to pull it out today for a look...
the issue is, the stock alt takes 2 bolts one from either side..
the falcon alt is done with just one..
the bottom bolt was about as tight as you would want it, given that its in a big ally housing, i didn't have to lever on it but some force was defently required.
i have orded a new mount (thanks jas) and will put a crush tube in it to stop the issue in the future..
i will add, i only put this alt in a few months ago! as my old one died from over tightening the bottom bolt :roll: ironic.
Vehicle: LWB Sierra & XL7
Post Posted: Mon Oct 10, 2011 5:34 am
It's not that bad.. :lol:
Use a high tensile bolt, that should help too.
'92 Vitara & Camper trailer
Vehicle: 03 Jimny
Post Posted: Mon Oct 10, 2011 6:52 am
Was the bolt a tight fit in the hole at the beginning?
Post Posted: Mon Oct 10, 2011 7:42 am
When I put the 110 alternator in my Sierra,
I never had to touch it again,
no adjustin was ever needed,
I used a Barina water pump, so kept the multi rib belt.
Post Posted: Mon Oct 10, 2011 8:22 am
yeah the mount was drilled out.. to 10mm so the fit was near perfect.
coilers run multi rib from factory ;)
Post Posted: Mon Oct 10, 2011 8:57 am
:oops: I'm still learning all this modern stuff :lol:
The vit may get a 110 when this one croaks.
Not a lot of room in there tho.
Post Posted: Mon Oct 10, 2011 8:59 am
Just turn the bolt around....
Post Posted: Mon Oct 10, 2011 9:13 am
shepped it. :P
Post Posted: Mon Oct 10, 2011 11:17 am
go get under a g13 sierra any will do and tell me why that won't work. not q bad idea tho lol
Post Posted: Mon Oct 10, 2011 6:42 pm
i use 2 bolts on the bottom with my falcon alt setup, neva had an issue.
but yes running with one bolt will require a crush tube
Vehicle: Yellow Ute
Post Posted: Tue Oct 11, 2011 6:43 am
STEKKY is giving you advice Jonno.
SO
Users browsing this forum: Google [Bot] and 115 guests
